Emf of a single loop wire around a solenoid
The discussion centers on calculating the magnetic flux through a wire loop surrounding a solenoid with specific dimensions and current. The solenoid has a diameter of 4 cm, a length of 20 cm, 250 turns, and carries a current of 15 A, while the wire loop has a diameter of 10 cm and is positioned perpendicular to the solenoid's axis. The magnetic field (B) generated by the solenoid is calculated using the formula B = (4π x 10^-7) * (number of turns) * (current), resulting in a value of 0.0264 T. The magnetic flux is then determined using the equation flux = B * A * cos(theta), yielding a final answer of 2.0735 x 10^-4 T*m^2. The confusion regarding the presence of an EMF is clarified, emphasizing that the question specifically asks for magnetic flux.
imatreyu
Sorry, the title is wrong. Should be "magnetic flux" of a single loop wire around a solenoid.
A solenoid 4 cm in diameter and 20 cm in length has 250 turns and carries a current of 15 A. It is surrounded by a loop of wire 10 cm in diameter. The loop is positioned perpendicular to and centered on the axis of the solenoid. Find the magnetic flux through the loop of wire. (The field outside of the solenoid is small enough to be negligible.)
E= N*A*B*w*sinwt ?
I don't know where to start...at all. How is there even an emf in the loop if the field around the solenoid is negligible?
There's no EMF, but the question is asking for the flux. What's the definition of flux?
flux is BAcostheta.I'm confused on what to use for B. . .since there's no field created by the solenoid.
Are you sure the solenoid doesn't create a magnetic field?
Actually. . . if someone could check my work:
B= 4pi x 10^-7 * 1400 turns * 15 A
= .0264 T
flux = BA cos theta
=.0264 T * (.0025 pi m^2)
=2.0735 x 10^-4 T*m^2
Answer = 2.0735 x 10^-4 T*m^2
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
