Emission current from hot cathode in an X-ray sourse
The discussion centers on the behavior of X-ray intensity in relation to emission current from a hot cathode. It is noted that the intensity levels off at high emission currents, likely due to the limited number of electrons that can be emitted and the resulting "space charge effect" that creates a cloud of electrons around the filament. This phenomenon prevents further increases in X-ray production unless the anode voltage is raised to extract the electrons more efficiently. Additionally, the saturation intensity was measured without aluminum in the beam path, revealing that the count rate with the aluminum block is significantly lower. The conversation highlights the complexities of measuring X-ray intensity and the factors influencing it, particularly at high emission currents.
proudtobeaj
Part of an experiment involved measuring the intensity of an X-ray beam through a piece of aluminium as a function of emission current of the X-ray source. I originally fitted a linear fit to my data (although it does start to level off at high emission currents). The marker however said that it was not a linear fit, and said it was heading towards "saturation", but I am not quite sure what he meant. The detector is definitely NOT at saturation as the measured intensities are well below the saturation level (measured earlier)
Why does the intensity of the beam level off at high emission currents? Is it because there can only be so many electrons "boiled off" from the cathode, so it can only produce so many X-rays in collisions with the target?
Was the saturation intensity measured with the same aluminum block interposed? Could the intensity on the source side of the block be higher than on the detector side?
The saturation intensity was measured with no aluminium in the path of the beam. the count rate (with the block in place) begins to level off at higher emission currents with only about half of the count rate of the beam whose path was unimpeded.
At some point as you heat the filament the electrons emitted from the filament begin to shield the filament with a cloud of electrons that have not been pulled out of the vicinity of the filament. Unless you increase the anode voltage and extract these electrons more quickly the flow will stop increasing. See "space charge effect"
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
