MHB Emwhy's question at Yahoo Answers regarding finding extrema in a given region
  • Thread starter Thread starter MarkFL
    Extrema
The discussion centers on finding the extreme values of the function f(x,y) = 6x^2 + 3y^2 - 36x - 1 within the region defined by x^2 + y^2 ≤ 36, using methods such as Lagrange multipliers and critical point analysis. The critical point found inside the region is (3,0), which is identified as a relative minimum. The boundary is examined using parametric equations, leading to critical points at (6,0) and (-6,0). The analysis concludes that the absolute maximum value is 431 at (-6,0) and the absolute minimum value is -55 at (3,0). This comprehensive approach effectively identifies the extrema within the specified region.
MarkFL
MHB
Here is the question:
Find the extreme values of f, on a given region? Using LaGrange multipliers?
Find the extreme values of f(x,y) = 6x^2+3y^2-36x-1, on the region described by x^2+y^2 <=36.
I'm pretty sure you have to use LaGrange multipliers. I ended up with lamba=0, x=3, y= +/-sqrt(27) which doesn't seem right. Additional Details
Actually I just got the absolute minimum value by taking partial derivatives of f with respect to x and y. How do I get the absolute max?
I have posted a link there to this thread so the OP can see my work.
Mathematics news on Phys.org
Re: emwhy's question at Yahoo! Questions regarding finding extrema in a given region
Hello emwhy,
First, let's find the critical values inside the given region. We do this by equating the partials to zero, and solving the resulting system:
We are given:
$$f(x,y)=6x^2+3y^2-36x-1$$
Hence:
$$f_x(x,y)=12x-36=12(x-3)=0$$
$$f_y(x,y)=6y=0$$
This gives us the critical point $(x,y)=(3,0)$. Since its distance from the origin is less than $6$, we know it is within the circular region.
Next, we may employ the second partials test to determine the nature of the critical point.
Let:
$$D(x,y)=f_{xx}(x,y)f_{yy}(x,y)-\left(f_{xy}(x,y) \right)^2$$
Thus:
$$D(x,y)=12\cdot6-\left(0 \right)^2=72>0$$
Since $$f_{xx}(3,0)=12>0$$ we conclude that the critical point $(3,0)$ is a relative minimum.
Now we want to check the boundary. In order to examine $f$ on the boundary of the region, we may represent the circle $x^2+y^2=6^2$ by means of the parametric equations $x=6\cos(t),\,y=6\sin(t),\,0\le t\le 2\pi$. Thus, on the boundary we can write $f$ as a function of a single variable $t$:
$$f(\cos(t),\sin(t))=f(t)=6\left(6\cos(t) \right)^2+3\left(6\sin(t) \right)^2-36\left(6\cos(t) \right)-1=108\cos^2(t)-216\cos(t)+107$$
Differentiating with respect to $t$ and equating to zero, we find:
$$f'(t)=-216\cos(t)\sin(t)+216\sin(t)=216\sin(t)\left(1-\cos(t) \right)=0$$
This gives us the critical values for $t$:
$$t=0,\,\pi,\,2\pi$$
Since the first and third critical values are boundary values for $t$, and because the parametrization of $x$ and $y$ have the same value for these two values, we need only consider:
$$t=0,\,\pi$$
This gives us the two critical points:
$$\left(x(0),y(0) \right)=(6,0)$$
$$\left(x(\pi),y(\pi) \right)=(-6,0)$$
Now, we may use the second derivative test to determine the nature of these extrema. Let's write the first derivative as:
$$f'(t)=-108\sin(2t)+216\sin(t)$$
Differentiating, we find:
$$f''(t)=-216\cos(2t)+216\cos(t)$$
Checking the critical values:
$$f''(0)=0$$
The second derivative test is inconclusive for this point, so using the first derivative test, we find:
$$f'\left(\frac{\pi}{2} \right)=216>0$$
$$f'\left(\frac{3\pi}{2} \right)=-216<0$$
Hence the point $(6,0)$ is a relative minimum.
$$f''(\pi)=-432<0$$
Hence the point $(-6,0)$ is a relative maximum.
So, we now know:
$$f_{\max}=f(-6,0)=6(-6)^2+3(0)^2-36(-6)-1=431$$
$$f_{\min}=f(3,0)=6(3)^2+3(0)^2-36(3)-1=-55$$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
