Energy and Work related - Did i do this right?
  • Thread starter Thread starter mks
    Energy Work
The discussion covers key concepts in physics related to energy and work. It defines potential energy as stored energy, with gravitational potential energy resulting from work against gravity. Work is described as the transfer of mechanical energy, while kinetic energy represents the energy of motion. The work-kinetic energy theorem explains the relationship between work done on an object and its kinetic energy. Additionally, the distinction between conservative and non-conservative forces is highlighted, emphasizing their impact on energy transfer.
mks
1. Potential energy- energy that is stored in by an object.
2. Gravitational potential energy- achieved by doing work against the force of gravity.
3. Work- the transfer of mechanical energy.
4. Kinetic energy- the energy of motion.
5. Mechanical energy- combination of kinetic and potential energy.
6. Work-Kinetic energy theorem- the special relationship between doing work on an object and the resulting kinetic energy of the object.
7. Negative work- removes energy from an object.
8. Positive work- adds energy to an object.
9. Conservative force- when a force does work on an object and the amount of work done is independent of the path taken.
10. Non-conservative force- when a force does work on an object and the amount of work done is path-dependent.
someone answer please.
*Bump*
What is your level of education?
high school, grade 11
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
