Energy conservation and friction
The discussion centers on a physics problem regarding energy conservation and the impact of mass on initial speed. It clarifies that while a greater mass increases both friction and kinetic energy, these effects cancel each other out, resulting in an initial speed that is independent of mass. Participants emphasize that the coefficient of kinetic friction is determined by the surfaces in contact, not the object's mass or normal force. The coefficient is defined as the ratio of the friction force to the normal force, and it is generally considered independent of normal force and speed. Understanding these principles is crucial for solving energy conservation problems in physics.
otownsend
Hi,
I just started learning physics at university and so I'm looking for help on a simple energy conservation problem. On the bottom right-hand of the image I attached below, you should see that it asks whether the initial speed would increase or decrease if the object was of a greater mass... why would the speed not change? In the calculations for initial speed, the co-efficient of static friction is included which varies depending on what surfaces are in contact with each other. I would therefore believe that the initial speed of the larger mass object would be greater, since the co-efficient would also be greater. Can someone please clarify this for me?
otownsend said:
Hi,
Look at the equation just above "Solve and evaluate." You will notice that the mass enters on both sides of the equation. So yes, the friction will be greater with the greater mass of the vehicle, but so will its kinetic energy. The two cancel out and the result is independent of the mass of the object.
Oh I think I understand what you mean!
The co-efficient of kinetic friction is just determined by the contacting surfaces (rubber and concrete in this example) and so the mass of the object does not affect this value.
I believe I was under the impression that the co-efficient of kinetic friction was determined by the normal force of the object (which indirectly means the mass of the object), which actually is not the case. The coefficient is merely the relationship between contacting surfaces of the same type and is discovered when comparing the ratio between the normal force and the friction force ... right?
otownsend said:
The coefficient is merely the relationship between contacting surfaces of the same type...
They don't have to be of the same type.
otownsend said:
... and is discovered when comparing the ratio between the normal force and the friction force ... right?
It's not "discovered when comparing the ratio", it simply is the ratio.
otownsend said:
The coefficient [...] is the ratio between the normal force and the friction force ... right?
Yes, but note that the ratio may or may not depend on the normal force. The usual approach is to adopt the approximation that the ratio is independent of the normal force and also independent of the speed.
Thread 'Is 'Velocity of Transport' a Recognized Term in English Mechanics Literature?'
Here are two fragments from Banach's monograph in Mechanics I have never seen the term <<velocity of transport>> in English texts. Actually I have never seen this term being named somehow in English. This term has a name in Russian books. I looked through the original Banach's text in Polish and there is a Polish name for this term. It is a little bit surprising that the Polish name differs from the Russian one and also differs from this English translation. My question is: Is there...
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
