Energy-Momentum Tensor for a particle
In summary, the conversation discusses the process of defining an energy-momentum tensor for a point particle. Two references are mentioned which both start with an action for a particle moving in space-time and then differentiate it with respect to the metric to obtain the tensor. However, the use of the Dirac delta function is necessary in order to convert the action into a Lagrangian density.
PML
Hello everyone,
I was studying how to define, formally, an energy-momentum tensor for a point particle.
I was reading this two references:http://academic.reed.edu/physics/courses/Physics411/html/page2/files/Lecture.19.pdf , page 1; and http://th-www.if.uj.edu.pl/acta/vol29/pdf/v29p1033.pdf page 1038.
They both start from an action that I understand, it's just the action for a particle moving in space time. They, then, differentiate the action with respect to the metric to get the energy-momentum tensor, but then, somehow, they arrive at an expression that has the dirac delta in it...
Can anyone help me out?
Thank you
That's because, as noted on page 2 of your first reference, the action in question needs to be a Lagrangian density, i.e., something you integrate over a 4-volume; but equation 19.1 of that paper, the usual action for a point particle in SR, is not a Lagrangian density. The delta function comes in when you try to make it one (basically because you have to pick out just the points in the 4-volume that lie on the point particle's worldline).
Related to Energy-Momentum Tensor for a particle
1. What is the Energy-Momentum Tensor for a particle?
The Energy-Momentum Tensor for a particle is a mathematical construct used in physics to describe the energy and momentum of a single particle in a given reference frame. It is a 4x4 matrix that contains information about the energy, momentum, and stress of the particle.
2. How is the Energy-Momentum Tensor calculated?
The Energy-Momentum Tensor is calculated using the energy and momentum of the particle in a given reference frame. It can be calculated using the equations of special relativity, which take into account the particle's mass, velocity, and direction of motion.
3. What is the significance of the Energy-Momentum Tensor?
The Energy-Momentum Tensor is significant because it allows us to understand the behavior of particles in terms of their energy and momentum. It is a fundamental concept in physics and is used in many areas of research, such as quantum mechanics and general relativity.
4. How does the Energy-Momentum Tensor relate to conservation laws?
The Energy-Momentum Tensor is closely related to the laws of conservation of energy and momentum. By studying the changes in the tensor, we can determine how energy and momentum are conserved in a given system. This is an important tool in understanding the behavior of particles and systems in physics.
5. Can the Energy-Momentum Tensor be used to describe systems with multiple particles?
Yes, the Energy-Momentum Tensor can be used to describe systems with multiple particles. In these cases, the tensor is expanded to include the energy and momentum of each individual particle, allowing for a more comprehensive understanding of the system as a whole.
