Energy-momentum tensor for the Dirac spinor
teddd
Hi there, I'm having a problem calculating the energy momentum tensor for the dirac spinor \psi (x) =\left(\begin{align}\psi_{L1}\\ \psi_{L2}\\\psi_{R1}\\ \psi_{R2}\end{align}\right)(free theory).
So, with the dirac lagrangian \mathcal{L}=i\bar{\psi}\gamma^\mu\partial_\mu\psi-m\bar{\psi}\psiin hand i should be able to figure out the energy momentum tensor by using the formulaT^\mu{}_\nu=\frac{\delta\mathcal{L}}{\delta \partial u_A}\partial_\nu u_A-\delta^\mu_\nu\mathcal{L}
and since we're assuming the equations of motion to be true we can forget of the latter term in the above equation, and focus on the former.
Here come the probelms.
First of all, I'm not sure on which values does the A index in the T^\mu{}_\nu forumula run: are they 1L, 2L, 1R, 2R?
If so, how can you tell me explicitly how to do the functional derivation \frac{\delta\mathcal{L}}{\delta\partial u_A}?
By writing explicitly the lagrangian (forgetting about the mass term) i get to
\mathcal{L}=i(\psi^*_{L1},\psi^*_{L2},\psi^*_{1R}, \psi^*_{2R})\gamma^0\partial_0\left(\begin{align} \psi_{L1}\\ \psi_{L2}\\ \psi_{R1}\\ \psi_{R2}\end{align}\right) +i(\psi^*_{L1},\psi^*_{L2},\psi^*_{1R},\psi^*_{2R})\gamma^1\partial_1\left(\begin{align}\psi_{L1}\\ \psi_{L2}\\\psi_{R1}\\ \psi_{R2}\end{align}\right)+i(\psi^*_{L1},\psi^*_{L2}, \psi^*_{1R},\psi^*_{2R})\gamma^2\partial_2\left (\begin{align}\psi_{L1}\\\psi_{L2}\\\psi_{R1}\\ \psi_{R2}\end{align}\right)+ i(\psi^*_{L1},\psi^*_{L2},\psi^*_{1R},\psi^*_{2R})\gamma^3\partial_3\left( \begin{align}\psi_{L1}\\\psi_{L2}\\\psi_{R1}\\ \psi_{R2}\end{align}\right)and I stop here becaouse those gamma matrices makes the calculation ridiculously complicated, which bring me nowhere.
Can you folks help me??
You don't need to vary each component of the 4-spinor separately, but you do need to independently vary both ψ and ψ, because these are the two values of uA. So you'd better first integrate by parts and write the Lagrangian in its symmetrized form: ½ψγμ(∂μψ) - ½(∂μψμψ + mψψ.
Taking the functional derivative δL/δ∂μψ is easy, because L is linear in ∂μψ.
That was my first guess.
But can you explain me the following issue then?
The spin angular momentum S^{\mu\lambda\kappa} is defined to be S^{\mu\lambda\kappa}=-i\frac{\delta\mathcal{L}}{\delta\partial_\mu u_A}(S^{\lambda\kappa})_{AB}u_Bwhere S^{\lambda\kappa}=\frac{i}{4}[\gamma^\lambda ,\gamma^\kappa].
Now here S^{\lambda\kappa}=\frac{i}{4}[\gamma^\lambda ,\gamma^\kappa] is a 4x4 matrix that acts on the 4 components of \psi (x) =\left(\begin{align}\psi_{L1}\\ \psi_{L2}\\\psi_{R1}\\ \psi_{R2}\end{align}\right), so I'm pushed to say that those A,B indicies on the (S^{\lambda\kappa})_{AB} actually run over the 4 values (1L 2L 1R 2R), and so do the ones of the u_A
Where am i mistaking?
Thanks for your time!
By the way, since the question has actually changed should I open a new post??
I am not sure if this belongs in the biology section, but it appears more of a quantum physics question. Mike Wiest, Associate Professor of Neuroscience at Wellesley College in the US. In 2024 he published the results of an experiment on anaesthesia which purported to point to a role of quantum processes in consciousness; here is a popular exposition: https://neurosciencenews.com/quantum-process-consciousness-27624/ As my expertise in neuroscience doesn't reach up to an ant's ear...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
This is still a great mystery, Einstein called it ""spooky action at a distance" But science and mathematics are full of concepts which at first cause great bafflement but in due course are just accepted. In the case of Quantum Mechanics this gave rise to the saying "Shut up and calculate". In other words, don't try to "understand it" just accept that the mathematics works. The square root of minus one is another example - it does not exist and yet electrical engineers use it to do...
