I Energy of an electron with Schrodinger's equation
cc94
Hello, I was trying to make a simple model of an electron tunneling through several potential barriers. The electron will flow through a conductor to a heterojunction of possibly semiconductor/oxide layers. I assume the electron is coming as a plane wave from the left with some energy E. We know that k = sqrt(E - V) for each layer, but my question is, how do you determine E and V? Is E the fermi level in the conductor? Is V half of the band gap, which is the distance something at the fermi level would have to tunnel to reach the conduction band of the semiconductor/insulator? This problem is likely more complicated than this, but I just need somewhere to start.
That expression doesn't have to work in solids. There will be a k(E) relation (dispersion relation), but it doesn't have to be a square root function. It depends on details of your material.
E is simply the energy of your incoming electron.
Likes bhobba
Thanks for the reply. For the energy of the incoming electron, is there a simple way to relate it to say the voltage on the circuit? I don't think applying 1 V on a circuit actually gives the electron 1 eV of energy, because the electron isn't freely accelerating in vacuum.
The absolute energy is meaningless, you need the energy relative to the potential only, and that will probably be less than 1 eV.
Ah I think I finally understand. So if I had a voltage drop of 1 V across the entire structure, the electron's energy is 1 V, because I can call the exit the zero of energy, so the electron is 1 V higher (i.e. the Fermi level of the entrance side is 1 eV higher than at the exit). The potential that the election sees will also slope downward towards the zero.
Likes bhobba
I read Hanbury Brown and Twiss's experiment is using one beam but split into two to test their correlation. It said the traditional correlation test were using two beams........ This confused me, sorry. All the correlation tests I learnt such as Stern-Gerlash are using one beam? (Sorry if I am wrong) I was also told traditional interferometers are concerning about amplitude but Hanbury Brown and Twiss were concerning about intensity? Isn't the square of amplitude is the intensity? Please...
I am not sure if this belongs in the biology section, but it appears more of a quantum physics question. Mike Wiest, Associate Professor of Neuroscience at Wellesley College in the US. In 2024 he published the results of an experiment on anaesthesia which purported to point to a role of quantum processes in consciousness; here is a popular exposition: https://neurosciencenews.com/quantum-process-consciousness-27624/ As my expertise in neuroscience doesn't reach up to an ant's ear...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
