B Energy & Pendulums: Is Negative Energy Real?
Paige_Turner
TL;DR Summary
A rising but slowing pendulum...
Does "absorbing" negative energy from gravity cancel the upward momentum of the pendulum?
Or what?
Where can I see energy being negative? Does it repel stuff?
It sounds impossible.
All we really know is that the pendulum slows down.. You need to know the math and the experimental result. The rest of it is made up, so we can make the words mean anything we wish
Write down the actual math. Is there any "energy" in it that is negative? (Hint: you can write down the math so that there is, but it won't mean what you seem to think it means.) You can even use the Newtonian math, which is simpler.
I asked a question here, probably over 15 years ago on entanglement and I appreciated the thoughtful answers I received back then. The intervening years haven't made me any more knowledgeable in physics, so forgive my naïveté ! If a have a piece of paper in an area of high gravity, lets say near a black hole, and I draw a triangle on this paper and 'measure' the angles of the triangle, will they add to 180 degrees? How about if I'm looking at this paper outside of the (reasonable)...
Thread 'Relativity of simultaneity in actuality'
I’m attaching two figures from the book, Basic concepts in relativity and QT, by Resnick and Halliday. They are describing the relativity of simultaneity from a theoretical pov, which I understand. Basically, the lightning strikes at AA’ and BB’ can be deemed simultaneous either in frame S, in which case they will not be simultaneous in frame S’, and vice versa. Only in one of the frames are the two events simultaneous, but not in both, and this claim of simultaneity can be done by either of...
