Energy released by condensing steam back to liquid water
In summary, by vaporizing 19 kg of water and not capturing and condensing it, it took 42.9 MJ of energy. This is equivalent to the amount of energy needed to vaporize the water, which is 2260 kJ/kg. However, this may not be accurate for realistic setups and efficiency should be taken into consideration.
corydm
vaporized 19 kg of water and did not capture and condense it. It took 42.9 MJ to vaporize the water, how much energy did I lose from not condensing the steam?
Latent Heat of Water = 2260kJ/kg
Would the energy lost to not capturing the condensation be the equivalent to the energy needed to vaporize the water?
If your initial water was completely pure, directly at the boiling point and your process was 100% efficient, probably. I doubt that for realistic setups, especially the last part. Anyway, you don't have to care about that to find the answer.
Related to Energy released by condensing steam back to liquid water
1. What is the process of condensing steam back to liquid water called?
The process of condensing steam back to liquid water is called condensation. This occurs when steam, which is water in its gas form, loses energy and transforms back into liquid water.
2. How is energy released during the condensation of steam?
Energy is released during the condensation of steam because when water vapor loses energy, the molecules slow down and come closer together, forming liquid water. This process releases the excess energy in the form of heat.
3. What is the source of energy for the condensation of steam back to liquid water?
The source of energy for the condensation of steam back to liquid water is the latent heat of vaporization. This is the amount of energy required to transform a substance from liquid to gas, or in this case, from steam to liquid water.
4. What is the relationship between temperature and energy released during the condensation of steam?
As steam loses energy and condenses back into liquid water, its temperature decreases. This is because the energy is being released in the form of heat, causing the temperature to drop. The lower the temperature, the more energy is released during condensation.
5. How is the energy released during the condensation of steam used in practical applications?
The energy released during the condensation of steam is often used in heating systems and power plants. In heating systems, the steam is used to heat up a liquid, such as water, which is then circulated through a building to provide heat. In power plants, the steam is used to turn turbines and generate electricity.
