A Energy transfer with current in a dielectric
Energy transfer in dielectrics occurs through electric fields rather than the movement of charges, similar to conductors when below the breakdown threshold. When a dielectric is subjected to a current that exceeds this threshold, it behaves like a conductor, allowing for continuous charge flow. The presence of a dielectric alters the electric field distribution, affecting impedance and energy propagation velocity compared to free space. During electrical breakdown, the dielectric becomes ionized, acting as a resistor, which halts energy propagation along the transmission line and can lead to energy loss through heat. Understanding these dynamics is crucial for applications involving dielectrics and energy transfer.
mcdonneldouglas
TL;DR Summary
Will the situation with energy transfer at current flow in a dielectric be similar to the case with a conductor?
It is known that when an electric current flows through a conductor, energy transfer occurs not by the movement of electrons, but by means of a field near the conductor.
In this case, will the situation with energy transfer when current flows in a dielectric be similar to the case with a conductor?
Above
Maybe I am not fully understanding your question, but I'll try to answer it.
As far as I understand it depends on the charge/current you put on the dielectric. If you put a current on the capacity that is below the break through threshold, then the molecules will only slightly adjust themselves to your current and act like an insulator, so energy transfer should happen via a field in your picture, not charges.
Once you cross the threshold, the dielectric will behave like a conductor. So yes, in both cases you get energy transfer via fields.
Likes mcdonneldouglas
Welcome to PF.
Energy propagates as EM waves in the space between ideal conductors. If that space contains an ideal dielectric, the energy will propagate through that dielectric, and will remain outside the conductors.
The presence of a dielectric will change the electric field distribution, so the impedance, and the velocity factor, of energy propagation will change slightly, when compared to free space.
Any electric or magnetic field that enters an imperfect conductor will be lost as heat in the conductor. The electric field that propagates through an imperfect dielectric, may heat the dielectric, and so also become an energy loss.
The electric charge within a dielectric, cannot flow continuously, but instead the charge is displaced elastically, in proportion to the electric field. That makes a capacitor. The virtual current in a dielectric is called a displacement current, to distinguish it from a conduction current, where a continuous flow of charge carriers is possible.
Energy can be guided and delivered to a port without involving conductors. An EM wave can be refracted or guided within a dielectric by local changes in the dielectric constant. Optic fibres are an example. Without controlled geometric changes in the dielectric constant, the energy would not be guided, but would be radiated in all directions.
Thank you for your answer!
So, can I ask you, which way(s) the energy flows during the dielectric's electrical breakdown when there actually is a continuous flow of charge?
If you want to study the energy propagation when the dielectric fails, you will need to specify a circuit schematic, and show the capacitor that will break down.
When a dielectric fails, it becomes an ionised path, a resistor. The energy then stops propagating along the transmission line, and is either reflected back to the source, or heats the dielectric in the region of breakdown.
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
