Energy use under different circumstances
  • Thread starter ksoth
  • Tags
    Energy
In summary, the debate revolves around whether or not using a StairMaster is the same as walking up stairs and whether potential energy is a factor in determining the difficulty of the workout. It is difficult to say who is right without further research and experimentation.
ksoth
Hello. New here.
Maybe someone can help answer a question that I was having a disagreement with someone over.
I recommended a friend use a StairMaster exercise machine to prepare for a hike. He claimed that StairMasters weren't as good as walking up large numbers of stationary stairs, as in his experience it was much easier to use the StairMaster. My claim was that it was easier because (most likely) he was holding on to the hand rails, and that if he didn't use the hand rails, the work out is (essentially) the same, neglecting minor differences of air resistance.
My friend claimed that because while walking on a StairMaster your elevation is not increasing, you aren't gaining any potential energy, therefor walking on a StairMaster is easier than walking up stairs by that factor. My argument is that you are gaining potential energy because with every step the machine removed potential energy, therefore you have to exert energy to bring you back up, and the net energy expenditure is the same. I used the argument that what if you took the StairMaster to the extreme and used an escalator instead, and if you went up the the top, let the escalator take you down, then go up. He agreed that this would be the same as walking up stairs, but because on a StairMaster the "give and take" of potential energy is happening at the same time, it's not an accurate representation and isn't the same thing.
Then, to try to reinforce the claim, he said replace this case with a motor attached to a cable that is oriented up/down and in such a way that there is no slippage between the motor and the cable. Turn the motor on and let it climb the cable. The motor requires X amount of energy to do this. His claim is that if you pulled the cable down, and turned the motor on such that it stays in the same spot, the motor uses less energy doing this than it does to climb the cable. My claim is that it takes the same amount of energy because in both cases you are doing the same thing: fighting gravity. His claim again is that because in the second scenario the motor isn't gaining any potential energy, it requires less energy to keep it in the same place.
Any thoughts on who is right?
Thanks in advance.It sounds like you and your friend have both made valid arguments. It is true that when walking on a StairMaster, one is not gaining any potential energy, which means that it might be easier than walking up stationary stairs. On the other hand, the amount of energy required to keep the motor in the same place is the same as it would take to climb the cable, since the motor is still fighting against gravity either way. Ultimately, it really depends on how much effort one is putting in when using a StairMaster; if they are holding onto the handrails, it will be easier than walking up stairs, but if they are pushing themselves to their physical limits, then it could be just as hard.
Related to Energy use under different circumstances
1. How does the energy use differ between industrial and residential settings?
In industrial settings, the energy use is typically higher due to the use of heavy machinery and equipment, as well as the need for heating and cooling large spaces. In residential settings, the energy use is lower as it primarily consists of lighting, heating/cooling smaller spaces, and using household appliances.
2. What is the impact of renewable energy sources on energy use?
The use of renewable energy sources, such as solar and wind power, can greatly reduce energy use as they do not produce greenhouse gas emissions and have a much lower environmental impact compared to traditional energy sources. However, the initial investment and infrastructure for renewable energy can be costly.
3. How does energy use vary between developed and developing countries?
Developed countries tend to have higher energy use due to their larger populations and higher standards of living. They also have more advanced technology and industries that require more energy. Developing countries, on the other hand, may have lower energy use due to a smaller population and less advanced technology, but may also lack access to reliable energy sources.
4. What are the effects of climate change on energy use?
Climate change can have a significant impact on energy use as extreme weather events, such as heat waves and cold spells, can increase the demand for energy to heat or cool buildings. It can also affect the availability and reliability of certain energy sources, such as hydropower, which relies on consistent water levels.
5. How can we reduce energy use in our daily lives?
There are many simple ways to reduce energy use in our daily lives, such as turning off lights when not in use, unplugging electronics when not in use, using energy-efficient appliances, and adjusting the thermostat by a few degrees. Additionally, using alternative modes of transportation, such as walking or biking, can also help reduce energy use from personal vehicles.
  • Classical Physics
  • Thermodynamics
12K
  • Mechanical Engineering
