- #36
DrChinese
- 1,913
I think @PeterDonis, @Morbert , @Demystifier et al have addressed these questions one way or another. But I will recap:kurt101 said:TL;DR Summary: I have some questions about entanglement swapping, realistic interpretations, and the monogamy entanglement argument that @DrChinese has been making that I want to ask about in an I-level thread.
For this discussion I would like to continue referring to the entangled pairs 1,2 and 3,4 as we have in previous discussions. For background on this discussion refer to post-selection: pre-existing correlations or action at a distance where @DrChinese describes the entanglement swapping experiments and his monogamy argument.
I think the entanglement swapping experiment is compatible with realistic interpretations that respect cause and effect such as argued in this paper http://philsci-archive.pitt.edu/9427/1/Delayed_Choice.pdf (Go to chapter 4 for the argument on the entanglement swapping experiment)
This paper is not disputing entanglement between 1 & 4 in the case where the BSM test is done prior to 1 & 4 being measured. I think it is accurate to say the paper and @DrChinese are in agreement here. And in the context of a cause and effect realistic interpretation, I don't see how anyone could argue for a coincidental explanation for this case, because you can always change the way you measure 1, 4 after knowing the result of the BSM test and so you have a cause and effect problem if you are suggesting a coincidental explanation for this case.
Where I think @DrChinese and the paper disagree is the case where the BSM test is done after 1 & 4 being measured. In a realistic interpretation with cause and effect, the cause can't happen after the effect. So while nobody disputes that 1 & 4 have an entangled correlation, the realistic explanation for the entanglement of 1 & 4 is one that requires coincidence between 1 & 4 versus causation; in other words 1 & 4 happened to have just the right initial states where their measurements resulted in an entangled correlation and a change to 2 & 3 so that the BSM test showed maximum entanglement.
It is my understanding that @DrChinese argument using monogamy of entanglement is in dispute with this second case where the BSM test is done after 1 & 4 being measured. I have read many definitions and gone through the proof that @DrChinese provided and I don't see how this second case where the BSM test is done after 1 & 4 is being measured is in violation of monogamy.
Taking one of the definitions that @DrChinese has previously referred to from https://www.quantiki.org/wiki/monogamy-entanglement
''Monogamy ''' is one of the most fundamental properties of entanglement and can, in its extremal form, be expressed as follows: If two qubits A and B are maximally quantumly correlated they cannot be correlated at all with a third qubit C.
My first question is how could you practically even test this? If monogamy is true in a realistic sense, then by definition it is untestable, since trying to measure a pair of entangled photons changes the entangled pair and as far as we know they would no longer be entangled after the measurement.
The other question, is in the case where the BSM test is done after 1 & 4 being measured, I can argue that 1 only became entangled with 4 after 1 was measured and after 4 was measured which means at no time was 1 entangled with both 2 & 4 and at no time was 4 entangled with both 3 & 1. So even if I did take the most strict view of entanglement of monogamy, it still is not violated in this case.
So please help me understand:
1) Is @DrChinese and his monogamy of entanglement argument in dispute with this view of cause and effect realism?
2) Assuming we are truly in disagreement, how does his monogamy of entanglement argument refute cause and effect realism in the case where the BSM test is done last?
- There is no experimental difference when the BSM on 2 & 3 (which is a required event) is performed before OR after the Bell test is performed on 1 & 4. Either way, 1 & 4 entanglement is confirmed by the violation of a Bell Inequality.
- Accordingly, from the reference, the following is simply incorrect: "Without delayed choice, this has physical significance, because each (A, D) pair actually is in such a state after the (B, C) measurement. But if the (A, D) measurements precede the (B, C) measurement, the (A, D) pair never is in any
of these states." The 1 & 4 (Egg's A & D) pairs are entangled if and only if a successful BSM occurs, regardless of when they occur. There are no "coincidental" violations of Bell Inequalities. - Monogamy of Entanglement applies regardless of when the BSM occurs. The timing defies the usual cause and effect relationship/ordering. You cannot reasonably say "The swap occurred at time X". You can only make the statement that "1 was initially entangled to 2, and was later entangled to 4." But at no time was 1 maximally entangled with both 2 and 4, as that defies MoE.
- For that to happen means that there was a change in the quantum state. We started with biphoton 1 & 2 and ended with biphoton 1 & 4. A biphoton has temporospatial extent which can exceed the usual Einsteinian limitations.
- If you are asking about "local realistic" interpretations, clearly those are long excluded due to Bell anyway. Extending the discussion to swapping with independent sources is simply going to fall further flat. If you want to be "realistic", you need to explain why the Bell State Measurement - which according to your position is NOT responsible for the ultimate entanglement of 1 & 4 (being just to identify 1 & 4 pairs with certain characteristics) - requires indistinguishability between 2 & 3. Because you can easily identify those same characteristics WITHOUT them being indistinguishable - and then 1 & 4 are not entangled! If the BSM is not an actual event responsible for the swap, why would they need to be indistinguishable? After all, you can still apply the same "filter" to identify the Bell State. Same 2 clicks.
