dRic2
- 225
Sometimes I go back and think about this stuff, and I always find something I don't understand very well.
Consider an irreversible isothermal expansion of an ideal gas from state ##A## to state ##B## and suppose I know the amount of heat given to the system to perform the expansion - I'll simply call it ##Q##.
First of all I need to evaluate the change in entropy between the two states. In order do this I forget about the irreversibility and I evaluate the change in entropy like this:
$$ T dS = de + pdV $$
I suppose the process is a reversible thermal expansion so, at constant temperature the change in internal energy ##de## is zero:
$$ dS = \frac p T dV = \frac {nR} V dV $$
$$ \Delta S_{A→B} = nR \ln \frac {V_{B}} {V_{A}}$$
This result should be correct because the entropy is a function of state so it does not care about the path taken (reversible or irreversible) to go from ##A## to ##B## as long as the initial and final states are the same.
I also know that, for a closed system, the following is true:
$$dS = dS_e + dS_i$$
where ##dS_e## is the entropy received by the system from the surroundings and it is equal to ##Q/T## where ##T##, in our case, is a constant. ##dS_i## is the entropy generated inside the system due to irreversibility.
Integrating and re-arranging the above equation:
$$\Delta S_i = \Delta S_{A→B} - \Delta S_e = \frac {Q_{rev}} T - \frac Q T = nR \ln \frac {V_{B}} {V_{A}} - \frac Q T$$
Since the generation of entropy should be greater than zero then ##Q_{rev} - Q > 0 ## or ##Q_{rev} > Q## which is very strange to me.
Did I miss something ? Is It wrong ?
