Epsilon Delta Limit Definition
MathSquareRoo
Prove lim x--> -1
1/(sqrt((x^2)+1)
using epsilon, delta definition of a limit
I know that the limit =(sqrt(2))/2
And my proof is like this so far. Let epsilon >0 be given. We need to find delta>0 s.t. if 0<lx+1l<delta, then l[1/(sqrt((x^2)+1)]-(sqrt(2))/2l < epsilon. So we need to pick delta= ?
I'm not sure how to arrive at the delta. I know I have to work out what's inside the absolute values, but I'm getting stuck.
MathSquareRoo said:
Prove lim x--> -1
1/(sqrt((x^2)+1)
What have you tried?
Where are you stuck?
I don't know how to simplify it at all. My thought was to maybe to get common denominator or and then multiply by the conjugate, but I don't know if this is correct. I got l[2-(2)^(1/2) *((x^2)+1)^(1/2)]/(2((x^2)+1)^(1/2)l. I'm sorry, it's hard to type it here, does any of that make sense?
Yes, that makes some sense.
What you have is: \displaystyle \left|\frac{2-\sqrt{2}\sqrt{1+x^2}}{2\,\sqrt{1+x^2}}\right| which is equivalent to: \displaystyle \left|\frac{1}{\sqrt{1+x^2}}-\frac{\sqrt{2}}{2}\right|. That's a start.
Rationalize the numerator. One factor of the result will be (x + 1) .
Restrict δ to put a bound on the rest of the expression.
When I try to rationalize, I get l(-2x^2)/[4((x^2)+1)^(1/2)+2(2)^(1/2)*((x^2)+1)]l
What did I do wrong?
The numerator should be 2(1-x2) which is 1(1-x)(1+x).
The denominator is a mess.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
