Equation for power required to overcome drag
  • I
  • Thread starter electrodacus
  • Tags
    Drag Power
In summary: This is strictly about this equation. It is one of the more important equations in physics in my opinion.
electrodacus
36
Here is the link to the equation I consider to be correct https://scienceworld.wolfram.com/physics/DragPower.html
Is anyone disagreeing with that and if so can you provide a link or screenshot from a proper textbook ?
The v in that equation is defined as speed of the fluid relative to the body.
It is the drag force multiplied by the speed which makes it the drag power. If drag power is what you're looking for, it is correct.
Likes electrodacus
Thread closed temporarily for Moderation...
Thread reopened, sort of...
Is this related to your two previously closed threads, and your temporary vacation from PF?
The question is as simple as stated. I asked if that is the correct equation ?
I think it is but I can always be wrong.
No. Just like a traffic cop stopping a car for rolling through a red light, the Mentors monitor your posting history and use it to Moderate future posts. We do not allow restarting locked threads, even if you initially try to hide your motives.
Under what assumptions? What are the assumptions behind that web page formula?
Not everybody seems to agree with that equation.
Maybe there is something that I'm missing or not understanding so I want to make sure that is the correct equation if I want to calculate the power needed by an object to overcome drag (any object traveling through a fluid).
The discussion on this thread will not go any further than confirming that equation is correct.
Who are the people who don't agree and what do they say? We can't have a proxy debate with people who aren't in the thread and are not cited.
The answer was given in post #2.
Yes post #2 has provided the answer that I consider to be correct thus I used the Like button for that post.
Even yourself disagreed with this equation in the past.
The claim if I remember correctly was that
- speed in that equation was the object/vehicle speed relative to ground times drag force
- while I was claiming that speed is the fluid speed relative to the object/vehicle.
Neither of those is true.
So, this is a continuation of your prior threads on DWFTTW, right? If not, where are we going from here?
https://www.google.com/url?sa=i&url...ved=0CA8QjRxqFwoTCIi7janK9fsCFQAAAAAdAAAAABAH
It gives me an error as video unavailable.
You will need this equation if you want to build a wind turbine or if you want to calculate the power needed for a vehicle of any type to overcome drag to name just a few examples for the use of this equation.
It's the theme music from the movie Jaws. It's meant to signify that you probably should not have tried to go for a swim at the same beach where you were bitten twice before...
:) funny.
But I do not think it applies to this case. I do not see how I was bitten ? To me it looks more like I was banned because people were thinking I invented or misused equations.
There is also a calculator that properly applies this equation correctly https://www.electromotive.eu/?page_id=12&lang=en
Thread closed again temporarily for Moderation. I will try to find your quote in your previous threads where you acknowledged that the video demonstrations were real. Give me a day or so please...
For if @berkeman chooses to re-open the thread:
Then since the question about the equation has been answered, the thread is finished, right?
[Edit] @berkeman has decided to keep the thread closed.
Likes berkeman
FAQ: Equation for power required to overcome drag
What is the equation for power required to overcome drag?
The equation for power required to overcome drag is P = Fd x v, where P is power, Fd is drag force, and v is velocity.
How is the equation for power required to overcome drag derived?
The equation is derived from the relationship between power, force, and velocity. Power is equal to force multiplied by velocity, and drag force is a type of force that opposes motion. Therefore, the power required to overcome drag is calculated by multiplying the drag force by the velocity of the object.
What factors affect the power required to overcome drag?
The power required to overcome drag is affected by several factors, including the shape and size of the object, the density and viscosity of the fluid it is moving through, and the velocity of the object.
How is the equation for power required to overcome drag used in real-world applications?
The equation is commonly used in the design and testing of vehicles, such as airplanes, cars, and boats. It helps engineers determine the amount of power needed to overcome drag and achieve optimal performance and efficiency.
Is the equation for power required to overcome drag always accurate?
The equation provides a theoretical estimate of the power required to overcome drag, but it may not always be accurate in real-world situations. Factors such as turbulence, air resistance, and other external forces can affect the actual power needed to overcome drag.
