MHB Equation of a Line Completing System with 3x - 2y = 8
  • Thread starter Thread starter JHPB99
    Line System
To create a system of equations with infinitely many solutions, the second equation must be identical to the first, which is 3x - 2y = 8. This means that any multiple of the original equation, such as 6x - 4y = 16, also works. However, simply repeating the original equation does not technically form a new system. The discussion highlights the importance of understanding that a valid system requires at least one equation to be a multiple of the other. Therefore, while the identical equation is correct, it does not fulfill the requirement for a distinct system.
JHPB99
Q: Write an equation of a line that forms a system with the equation 3x - 2y = 8 that has infinitely solutions.
A: 3x - 2y = 8.
I believe this to be correct because it makes an identical line to one of her correct answers (6x - 4y = 16) and nowhere did it specify that it had to be new. Could you tell me my mistake?
Mathematics news on Phys.org
Did you really think that your teacher intended you to just copy what she had written? On a technical level repeating the same equation does NOT give a "system".
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
