Equation of a plane perpendicular to 2 other planes
XtremeThunder
Greetings, I am have a bit of a problem getting started on the following problem. The only thing that is confusing me is I am use to seeing a problem like this be perpendicular to 1 plane and not 2.
The problem I am working with is as follows:
Find the equation of a plane through the origin and perpendicular to the planes given by x-y+z=5 and 2x+y-2z=7.
I just need some direction on where to start.
Edit:
I am not quite sure what to do with both planes given.
The final equation should look similar to the following, correct?:
?(x-0)+?(y-0)+?(z-0)=0. Again, I am not sure how to come up with the coefficients using two given planes.
I spent about 4 hours on this problem and feel really lost and stupid!
-Joe
Are you familiar with the concept of normal vector ?
Yes, I am familiar with the concept of a normal vector.
Would I be correct in saying each plane's normal vector is i-j+k and 2i+j-2k, or is that totally off base?
Or would I use the cross product between the two?
Yes,exactly. If the new plane is perpendicular to both the given planes, its normal vector must be perpendicular to the normal vectors of both given planes- and thus parallel to the cross product of the two normal vectors
The coefficients of the equation of my first post (?(x-0)+?(y-0)+?(z-0)=0) would be the coefficients of the result of the cross product between the two normal vectors i-j+k and 2i+j-2k, correct, which would be the final answer?
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
