Equation of Heat: Meaning of ζ
  • Thread starter Thread starter ssky
    Heat
The discussion centers on the physical meaning of the Greek letter zeta (ζ) in the context of heat equations. It is defined as ζ = sign(T₀ - Tₑ), where ζ equals +1 when heating from below and -1 when heating from above. Participants express confusion about why ζ takes these specific values and the implications for heat flux across a plane. The key point is that the sign of ζ indicates whether the fluid temperature is above or below the external temperature, influencing the direction of heat transfer. Understanding this distinction is crucial for interpreting heat flow dynamics in various heating scenarios.
ssky
Hi,
I have an equation of heat, as the form
gif.latex?\frac{\partial%20\theta%20}{\partial%20t}-\zeta%20w=\bigtriangledown%20^{2}\theta.gif
where,
[PLAIN]http://latex.codecogs.com/gif.latex?\zeta = +1 when heating from below
and
[PLAIN]http://latex.codecogs.com/gif.latex?\zeta = -1 when heating from above
what is the physical meaning of [URL]http://latex.codecogs.com/gif.latex?\zeta?[/URL]
Science news on Phys.org
That symbol represents the heat flux across or through a plane, according to wiki. The symbol is a greek letter zeta.
sorry,
i forget to write that
[URL]http://latex.codecogs.com/gif.latex?\zeta[/URL] =sign (T_{0}-T_{u})=+1
[URL]http://astro.temple.edu/~davatzes/Geothermal/Geothermal/What_is_Energy_files/Fig33.png[/URL]
and
[URL]http://latex.codecogs.com/gif.latex?\zeta[/URL] =sign (T_{0}-T_{u})=-1
why equal 1 and -1 ?
what is the physical meaning ?
Yes, but I'm confused about the[URL]http://latex.codecogs.com/gif.latex?\zeta[/URL] [/URL]
[URL]http://latex.codecogs.com/gif.latex?\zeta[/URL] =sign (T_{0}-T_{u})=+1 ?
and why equal +1?
pleas help me :cry:
and why equal +1?
pleas help me :cry:
You have left out what your various symbols stand for, which made me reluctant to answer since I have to guess.
Well, here's my guess.
It makes a difference whether the fluid is heated with a heater, so the temperature of the fluid starts being lower than the external temperature of the heater.
Or whether the fluid is not heated, but is cooling down.
Note that is won't matter if you have the heater on the bottom or on the top (it seems you're saying that).
What matters is whether the fluid temperature is above the temperature of the environment, or below.
Been around 40 years since I took basic physics in college and while I remember doing some examples of insulation values / energy conduction, I doubt I could to the math now even if I could find the formulas. I have some some corrugated plastic sheet (think of the plastic signs you see on the side of the road) that is used in bee hives. Also have some used in a green house though a bit different in dimensions than this example but the general approach should still apply. Typically, both...
Problem: You’re an Uber driver with a Tesla Model 3. Today’s low: 30F, high: 65F. You want to reach a USD$ profit target in the least number of hours, but your choices could have added cost. Do you preheat the battery only when you are headed to the charging station (to increase the charging rate by warming the battery — however the battery might not be “warm enough” when your reach the charger and thus slower charging rates), or do you always “navigate to the charger” the entire day (which...
Thread 'Is Callen right in claiming dQ=TdS for all quasi-static processes?'
Hello! I am currently reading the second edition of Callen's Thermodynamics and an Introduction to Thermostatistics, and I have a question regarding Callen's definition of quasi-static. On page 96, Callen says: Another way of characterizing Callen's definition is that a process is quasi-static if it traces out a continuous curve in the system's configuration space. So far it's all well and good. A little later, Callen claims that the identification of $$TdS$$ as the heat transfer is only...
