MHB Equation of Line Passing Through \(A(-5,-4)\) & \(B, C\) & \(D\)
  • Thread starter Thread starter sbhatnagar
    Line
To find the equation of the line passing through point \(A(-5,-4)\) that intersects three given lines at points \(B\), \(C\), and \(D\), the gradient \(m\) of the line is established using the relationship \(\frac{y_i+4}{x_i+5}=m\) for each intersection point. The coordinates of points \(B\), \(C\), and \(D\) are determined by substituting \(x\) and \(y\) values into the equations of the respective lines. By expressing the coordinates in terms of \(m\) and applying the condition \(\left(\frac{15}{AB}\right)^2 + \left(\frac{10}{AC}\right)^2 = \left(\frac{6}{AD}\right) ^2\), the value of \(m\) can be calculated. Ultimately, this leads to the determination of the line's equation. The method outlined provides a systematic approach to solving the problem.
sbhatnagar
A line through \(A(-5,-4)\) meets the lines \(x+3y+2=0\), \(2x+y+4=0\) and \(x-y-5=0\) at the points \(B, \ C\) and \(D\) respectively. If
\[\left(\frac{15}{AB}\right)^2 + \left(\frac{10}{AC}\right)^2 = \left(\frac{6}{AD}\right) ^2 \]
, find the equation of the line.
Mathematics news on Phys.org
Hi sbhatnagar, :)
I shall outline the method to solve this problem.
Let \(m\) be the gradient of the line through \(A(-5,-4),\,B(x_{1},y_{1}),\,C(x_{2},y_{2})\mbox{ and }D(x_{3},y_{3})\). Then,
\[\frac{y_i+4}{x_i+5}=m\mbox{ for each }i=1,\,2,\,3\]
Also since the points B, C and D are on the lines given by \(x+3y+2=0\), \(2x+y+4=0\) and \(x-y-5=0\) respectively, we have,
\[x_1+3y_1+2=0\]
\[2x_2+y_2+4=0\]
\[x_{3}-y_{3}-5=0\]
Using the above six equations we can find \(x_1,\,x_{2},\,x_{3},\,y_1,\,y_{2},\mbox{ and }y_{3}\) in terms of \(m\).
Finally using the given equation, \(\left(\frac{15}{AB}\right)^2 + \left(\frac{10}{AC}\right)^2 = \left(\frac{6}{AD}\right) ^2 \) the value of \(m\) can be found. Hence the equation of the line can be determined.
Kind Regards,
Sudharaka.
My solution can be found in the spoiler.
Let equation of line \(AC\) be
\[\frac{y+4}{\sin \theta}=\frac{x+5}{\cos \theta}=r\]
Let line \(AE\) make angle \(\theta\) with the \(x\)-axis and intersects \(x+3y+2=0\) at \(B\) at a distance \(r_1\) and line \(2x+y+4=0\) at \(C\) at a distance \(r_2\) and line \(x-y-5=0\) at \(D\) at a distance \(r_3\).
\[\therefore \ AB=r_1 , \ AC=r_2, \ AD=r_3\]
Putting \(x=r_1\cos \theta -5\) and \(y=r_1\sin \theta -4\) in \(x+3y+2 =0\) we get
\[\begin{aligned}
x+3y+2 &=0 \\
\Rightarrow r_1 \cos \theta -4 +3(r_1 \sin \theta -4)+2 &=0 \\
\Rightarrow r_1 &= \frac{-5-3(4)+2}{\cos \theta +3 \sin \theta} \\
\Rightarrow r_1 &= \frac{15}{\cos \theta +3 \sin \theta} \quad \cdots \text{(i)}
\end{aligned}\]
Similarly,
\[\begin{aligned}
r_2 &= \frac{10}{2\cos \theta + \sin \theta} \quad \cdots \text{(ii})\\
r_3 &= \frac{6}{\cos \theta - \sin \theta} \quad \cdots \text{(iii)}
\end{aligned}\]
But it is given that
\[\begin{aligned} \left(\frac{15}{AB}\right)^2 + \left(\frac{10}{AC}\right)^2 &= \left(\frac{6}{AD}\right)^2 \\ \Rightarrow \left(\frac{15}{r_1}\right)^2 + \left(\frac{10}{r_2}\right)^2 &= \left(\frac{6}{r_3}\right)^2 \\ \Rightarrow (\cos \theta + 3\sin \theta )^2+(2\cos \theta + \sin \theta)^2 &=(\cos \theta -\sin \theta)^2 \quad [\text{from equations (i), (ii) and (iii)}] \\ 4\cos^2 \theta + 6 \sin ^2 \theta +12 \sin \theta \cos \theta &=0 \\ (2\cos \theta + 3 \sin \theta )^2 &=0 \\ 2\cos \theta + 3 \sin \theta &=0 \\ \tan \theta &=-\frac{2}{3}\end{aligned}\]
On substituting this in the equation of \(AC\), we get
\[y+4=(x+5)\tan \theta \\ \Rightarrow y+4=-\frac{2}{3}(x+5) \\ \Rightarrow 2x+3y+22=0\]
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
11K
