Equations of a Plane: Determining if a line lies within a plane
  • Thread starter Thread starter Buzzlastyear
    Line Plane
To determine if the line defined by (x, y, z) = (5, -4, 6) + u(1, 4, -1) lies within the plane described by (x, y, z) = (3, 0, 2) + s(1, 1, -1) + t(2, -1, 1), the point (5, -4, 6) was tested and found to lie in the plane. However, further analysis showed that substituting values for u, s, and t revealed inconsistencies, indicating that the line does not lie entirely within the plane. The conclusion drawn is that the line intersects the plane at one point but does not lie within it, as demonstrated by testing multiple points on the line. Ultimately, the line is parallel to the plane and does not lie in it.
Buzzlastyear
Does the line with equation (x, y, z) = (5, -4, 6) + u(1,4,-1) lie in the plane with equation (x, y, z) = (3, 0, 2) + s(1,1,-1) + t(2, -1, 1)? Show algebraically.
I really have no idea where to start so I put the equations into parametric form to try to jog my brain but still got me nowhere!
(x,y,z)=(5,-4,6) + u(1,4,-1)
x=5+u
y=-4+4u
z=6-u
(x,y,z)=(3,0,2) + s(1,1,-1) + t(2,-1,1)
x=3+s+2t
y=s-t
z=2-s+t
EDIT: I was looking back in some of my notes and although there was nothing on how to determine if a line lies within a plane, I found how to determine if a point does. So I discovered that the point from the first vector equation (5,-4,6) does indeed lie within the plane (x,y,z)= (3, 0, 2) + s(1,1,-1) + t(2, -1, 1). After discovering this however, i still don't see how i can use this information to see if the line (x,y,z)=(5,-4,6) + u(1,4,-1) lies within the plane
Not sure but maybe i have to sub in a value for s or t and solve the equations? i really have no leads so any help is very much appreciated thank you!
EDIT 2: I think i may have figured it out, here is what I've done:
substitute a value for u, ex. let u = 0
solve (x,y,z)=(5,-4,6)+0(1,4,-1)
therefore (5,-4,6) is a point when u=0
sub the values of x,y, and z into the parametric equations of the plane:
x=3+s+2t, y=s-t, z=2-s+t
6=3+s+2t, 0=s-t, 5=2-s+t
...s=t
sub s=t in 6=3+s+2t
6=3+t+2t
t=1
Sub t=1 in s=t
s=t
s=1
Now sub s=1 and t=1 into 5=2-s+t
LS=5 RS=2-s+t
RS=2-1+1
RS=2
Therefore the line (x,y,z)=(5,-4,6) + u(1,4,-1) does not lie in the plane??
Find two points on your line and determine whether they satisfy the equation of your plane.
If both points on the line satisfy the plane equation, the line is in the plane.
If only one point satisfies the plane equation, the line intersects the plane but doesn't lie in it.
If neither point on the line satisifies the plane equation, the line is parallel to the plane and doesn't lie in it.
Thank you
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 21 ·
