Equations relating changes between rotating and inertial frames
The discussion focuses on the relationship between acceleration in inertial and rotating frames, specifically through the equation a(I) = a(R) + 2(omega)Xv(R) + (omega)X(omega)Xr. It highlights the application of this equation to systems like Foucault's pendulum, where acceleration changes need to be accounted for. A key point raised is the confusion about applying the equation when an object, such as a train, moves at constant velocity, questioning whether the simpler relation V(I) = V(R) + omega X (V(R)) is sufficient. Clarification is provided that the correct form for velocity is V(I) = V(R) + omega X r, emphasizing that the original equation still accounts for Coriolis acceleration even when velocity is constant. The discussion concludes with an understanding of when to apply these equations in relation to inertial and rotating frames.
bman!!
i understand the reason and steps leading to the equation that relates acceleration in the inertial frame to acceleration in the rotating frame i.e.
a(I) = a(R) + 2(omega)Xv(R) + (omega)X(omega) X r
a(I) = acceleration in inertial frame
a(R) = acceleration in rotating frame
omega = rotation vector
X = cross product
v(R) = velocity in rotating frame
r = position vector
now i understand why this (or a rearrangement thereof) can be applied to a system like focaults pendulum, becuase you have acceleration going on, so obviously you would want to relate the changes between the two frames.
however, everyone remembers the simple problems where you simply use the coriolis term to calculate the direction and magnitude of the coriolis force on something like a moving train (i.e. 500 tonne train moving north at 100kph experiences a coriolis force of something liek 1500N eastwards)
however it struck me, that if the train is moving with constant velocity, then surely the above equation doesn't apply? and surely the equation linking the two vectors a together is simply the very original relation between the two frames for vector that is fixed in the rotating frame namely:
or is it more subtle than this?
Your original equation shows that there is a Coriolis acceleration even if v is constant wilth respect to the Earth. That just means a(R)=0.
ah i see, that makes sense.
but when would
be applicable? or is it just an intermediary?
bman! said:
but when would
Never! Look at the units on the right-hand side. The first term has units of velocity, the second, acceleration. The equation you are looking for is
\mathbf v_I = \mathbf v_R + \mathbf \omega \times \mathbf r
So when does this equation apply? Simple: When you want to know the velocity of some object as seen by an observer fixed in the inertial frame.
ah i see now. cheers.
Thread 'Is 'Velocity of Transport' a Recognized Term in English Mechanics Literature?'
Here are two fragments from Banach's monograph in Mechanics I have never seen the term <<velocity of transport>> in English texts. Actually I have never seen this term being named somehow in English. This term has a name in Russian books. I looked through the original Banach's text in Polish and there is a Polish name for this term. It is a little bit surprising that the Polish name differs from the Russian one and also differs from this English translation. My question is: Is there...
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
