Equilibrium of Objects: Finding Reactions of a Diving Board with Weights
  • Thread starter Thread starter lukasz08
    Equilibrium
The discussion focuses on calculating the reactions at points A and B of a diving board with weights. The total downward force is calculated as the sum of the weights of the diving board and the person, resulting in a force of -882.9N. The user initially struggles with the calculations but ultimately determines the reactions to be Ax = 0, Ay = -1870N, and By = 2740N. The problem highlights the importance of balancing forces in static equilibrium. The user successfully resolves the issue independently.
lukasz08
A_________B____________Wd_________Wp_
|--1.2m--|----1.2m------|---2.2m-----|
Above is a diving board with 2 weights on it. determine the reactions of A and B
wd= 36kg = weight of diving board
wp= 54kg = weight of person standing on diving board
point A = pin support
point B
Ok so the sum of the forces in the x and y directions are as follows x = 0 because their are no x components. Y = -54gk(9.81m) + (-36kg(9.81m)) = 529.74 + 353.16 = -882.9N. After this i do not know what to do.
Answers are Ax= 0, Ay = -1870N, By=2740N
Nevermind i have figured it out
Thread 'Have I solved this structural engineering equation correctly?'
Hi all, I have a structural engineering book from 1979. I am trying to follow it as best as I can. I have come to a formula that calculates the rotations in radians at the rigid joint that requires an iterative procedure. This equation comes in the form of: $$ x_i = \frac {Q_ih_i + Q_{i+1}h_{i+1}}{4K} + \frac {C}{K}x_{i-1} + \frac {C}{K}x_{i+1} $$ Where: ## Q ## is the horizontal storey shear ## h ## is the storey height ## K = (6G_i + C_i + C_{i+1}) ## ## G = \frac {I_g}{h} ## ## C...
