Equilibrium Position of Charged Ball near Charged Plate
The discussion focuses on calculating the equilibrium position of a positively charged sphere hanging from a charged plate. Participants emphasize the need to balance the forces acting on the sphere, including gravity and the electric force from the plate. The tension in the string must be resolved into horizontal and vertical components to find the angle the string makes with the vertical. Additionally, the electric field due to the charged plate is clarified as being independent of distance, which is crucial for deriving the angle in terms of the charge on the sphere. The conversation also touches on estimating the capacitance between the sphere and the plate once the equilibrium position is determined.
VictorWutang
A small positively charged sphere of mass m is attached to a very large positively charged vertical plate by a string and hangs due to gravity. The charge density on the plate, σ, is uniform.
a) Calculate the equilibrium position of the ball as a function of the (uniformly distributed) charge on the ball. I.e. what angle does the string make with the vertical?
b) estimate the capacitance between the sphere and the plate.
F = kqσ / r2 (not sure if this is correct)
E = kq / r
a) Pythagorean theorem will come into use. I have to find where the force due to the magnetic field of the plate is equal to the force of gravity resisting it, but I can't figure out how to make the force of gravity,the force of the electric field and the tension/normal force to be in vectors that cancel out. More specifically, i can't figure out how to express the downward force of gravity to be perpendicular to the plate to cancel out the force from the plate.
b) once i find this distance, capacitance will just be ε0*A / d with A being ∏r2 with r being the radius I would estimate the ball to be.
E = kq / r
Hello VictorWutang,
For the first part the tension acts as the balancing force.Its horizontal component balances the electric force due to plate and the vertical component balances gravity.
regards
Yukoel
So is the x component of tension is sinθ * Ftension?
and then Ftension is mass * gravity?
Hello VictorWutang,
The tension needs to be resolved both vertically and horizontally right?
So Ftension is mass * gravity?[/QUOTE]
doesn't sound correct.Would you put a picture of where you take your angle from?
| 8
I think the oblique slashes represent the string in your diagram the vertical slashes the plate and 8 the charge .
Please check again.
EDIT: Spaces were automatically truncated in my reply.So apologies for the confusing diagram .
regards
Yukoel
yes, that's what the diagram looks like. and θ is the angle I'm looking for, the angle between the wall and the rope
Hello again,
Then wouldn't Tsinθ=Electrical force(Calculate)
and Tcosθ=Weight ?
You can eliminate tension from your equations wouldn't you?
regards
Yukoel
so electrical field is E = .5kσ/r and electrical force is F = qE so
Tsinθ = F = qE = .5qkσ/r, also Tcosθ= mg giving us T = mg/cosθ so
mgtanθ = .5qkσ/r so
θ = tan-1 (.5qkσ/rmg) but r in this case is the distance not the radius, and we want to put θ in terms of q being variable
so how can i put r in terms of q?-----also, if you could help with the other two problems i posted i'd really appreciate it. you're a big help on this one too.
mgtanθ = .5qkσ/r so
Hello again,
The field due to an infinitely long sheet of charge with a given charge density σ
is given by (σ/(2ε_o))It is not a function of r.Your expression for E when revised would lend you the desired result.
regards
Yukoel
Yukoel said:
Hello VictorWutang,
| 8
Please check again.
Yukoel
I draw a picture with Paint and uploaded. It looks nicer than that made of characters :smile:
ehild
