I Equivalence Question between when-then statement and if then statement
The discussion centers on the equivalence of "when-then" statements and "if-then" statements in logic. The original poster is confused about which proposition to assume for a proof involving "when p is true, then q is true." Participants clarify that "when" can often be interpreted similarly to "if," suggesting that the statement does not imply a temporal condition. Some also note that language differences, particularly in translation, may contribute to the confusion. Ultimately, the consensus is that "when" can be treated as "if" in logical contexts.
cbarker1
MHB
TL;DR Summary
What is the equivalence between when then and if-then statement
Dear Everybody,
I am working on my homework. I am trying to prove a problem that was written by my professor in an odd way: Prove that when p is true, then q is true. Which proposition statement should I assume? I personally thought that I should assume the first one. But reading my introduction to proof writing it says "Q, when P for implication statement." Now, I am confused on what to assume?
Thanks,
Cbarker1
Mathematics news on Phys.org
Who wrote the book? I'm pretty sure we can assume "if" in those cases, except in case the statement is time-dependent.
I forgot to add that my professor wrote the problem.
I was asking because it might be a language issue. "If" in German is "wenn" so it could be a translation problem. Another, possibly more likely reason could be that "when" is commonly used in the same sense as "if", disregarding the timely connotation of "when". When it happens it does not necessarily require a time scale. It simply means if it happens.
cbarker1 said:
TL;DR Summary: What is the equivalence between when then and if-then statement
Dear Everybody,
I can't see that "when p is true, then q is true" could possibly mean "if q, then p". Words and phrases like "assuming", "whenever", "when", "in the event that", "under the assumption that" etc. are sometimes used instead of the more formal "if".
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
