Equivalent acceleration of an accelerometer
The discussion revolves around the concept of equivalent acceleration in accelerometers and the implications of inertial versus non-inertial reference frames. Participants clarify the relationship between forces and accelerations, noting that the negative signs in the equations arise from balancing inertial forces with restoring forces in the accelerometer. When an accelerometer is swung in a positive direction, the output can be either positive or negative, depending on whether it reports the system's acceleration or the apparent acceleration of the mass. The confusion regarding the sign of gravitational acceleration (g) is addressed, highlighting that it depends on the calibration of the accelerometer and the context of measurement. Overall, understanding these principles is crucial for interpreting accelerometer outputs accurately.
ylim
Hi there,
I am reading this old journal and found this formulaes.
forces on the seismic mass, expressed in inertial reference coordinates, are given by Newton's law as
sum of force in x direction = m * x''
sum of force in y direction = m * y'' = Fy = mg
the equivalent acceleration of the accelerometer are
ax = -F/m = -x''
ay = -F/m = -y'' - g
i am rather concerned with the change in sign direction. i vaguely understand the concept of inertial and non inertial ref frame. but i don't know why it will cause a diff to the axial acceleration. hope to hear from someone.
I'm not sure I understand your notation (Fy is force in the y direction, and ax and ay are accelerations in the x and y directions, right? x" is also acceleration in x direction?)
In any case, however, the negative signs probably come from balancing the inertial force on the test mass, which results from the external acceleration that you're measuring, with the restoring force of the spring (assuming that's what supplies the balancing force in the accelerometer) - equal and opposite forces, you know. In other words, if the system is accelerating to the right (positive direction), the mass will swing to the left (negative direction), so it applies a force in the negative direction. If you want to think about the non-inertial frame of the accelerometer, it just means that a tiny observer in that frame would see the mass move to the left and interpret that as a force (and acceleration) to the left.
That's my guess, anyway - it's kind of hard to be sure since you haven't given much explanation.
this will come to a qn which i have, i have an accelerometer, when i swing it to its positive direction, will it be a positive or a negative output?
so (to be more specific) to a right accelerating accelerometer (positive is right), what should be my output? positive or negative?
- Yes.
i guess we can see it when one is a in plane, when it is accelerating, we cannot anticipate/follow up, so we get push back to our seats? the seats gives the 0 opposite force, which is the spring in your explanation?
BUT, the weird thing is the sign of the g. which is -g? in the case of a resting accelerometer, in a inertial ref frame, it should be -1g. but in a non-inertial, it should be +1g? I notice this from a analog devices (crossbow) development board i have.
The output can be either - it's just a matter of convention. If the output reports the calculated acceleration on the whole system, then it will be positive (in your example). If it reports the apparent acceleration of the mass in the non-inertial internal system (which is the "raw" information it measures) and leaves you to convert that back to the system acceleration, then it would report a negative (left) acceleration.
Yes, I think you're correct about the plane example: the plane accelerates forward during take-off, but inside, in our non-inertial frame, we feel a force that accelerates us backwards into the seat. We stop when the seat cushion is compressed enough to provide an opposing force equal to the inertial force of our bodies, and if the cushion happened to calibrated to provide a nice measurement of that compression, we could determine the rate of acceleration of the plane.
As for the factor of g, that has to do with whether we're reporting the "sensed" acceleration or the "true" acceleration. This in turn depends on how the accelerometer is calibrated, i.e. under what circumstance does it read 0 vertical acceleration. It could be when it is at rest, i.e. when it senses an acceleration of -g, or it could be when it is actually falling at an acceleration of -g, so it senses no net acceleration.
Thread 'Is 'Velocity of Transport' a Recognized Term in English Mechanics Literature?'
Here are two fragments from Banach's monograph in Mechanics I have never seen the term <<velocity of transport>> in English texts. Actually I have never seen this term being named somehow in English. This term has a name in Russian books. I looked through the original Banach's text in Polish and there is a Polish name for this term. It is a little bit surprising that the Polish name differs from the Russian one and also differs from this English translation. My question is: Is there...
Some physics textbook writer told me that Newton's first law applies only on bodies that feel no interactions at all. He said that if a body is on rest or moves in constant velocity, there is no external force acting on it. But I have heard another form of the law that says the net force acting on a body must be zero. This means there is interactions involved after all. So which one is correct?
