Engineering Equivalent circuit with resistors neither in series nor parallel
To find the equivalent resistance between terminals a and b in a complex resistor network, applying Kirchhoff's laws and methods like mesh or nodal analysis is essential. One approach involves adding a 1 amp current source at node a and using node b as the reference point to calculate the voltage at node a, allowing for the determination of equivalent resistance as V/I. Alternatively, a delta-Y conversion can simplify the problem, enabling the use of standard series and parallel resistor techniques. Understanding the methods available is crucial for tackling the problem effectively. The discussion emphasizes the importance of foundational circuit analysis techniques in solving complex resistor networks.
chollins
all resistors have arbitrary values. the equivalent resistance needs be found between terminal a and b.
I have not got a clue how to tackle this problem. as such there is no attempted solution either.
any help would be great.
chollins
Do you know how to solve a network?
Have you studied Kirchoff's current and voltage laws?
Have you studied the mesh, loop, or nodal methods for solving networks?
We would need to know how far your studies have gone to determine what method would work best for you.
I have done Kirchoff's current and voltage laws and their applications in mesh, loop and nodal analysis.
I'm not sure how they will help with this problem as it is an open-circuit resistance that is being calculated.
but i could be wrong of course.
thank you for your reply
chollins
What you have to do is to add a current source, supplying a current of 1 amp into node a; let node b be your reference node (ground).
Then solve the network for the voltage at node a. Knowing the current I into node a (1 amp) and the voltage V at node a, the equivalent resistance will be V/I.
yeah, makes sense. I will do it later today as right now i need to sleep.
thanks for the help.
chollins
A much simpler way, for me at least, is to use the delta-Y conversion. That way you can use the normal series and parallel connections, without having to resort to KCL and KVL.
Thread 'Have I solved this structural engineering equation correctly?'
Hi all, I have a structural engineering book from 1979. I am trying to follow it as best as I can. I have come to a formula that calculates the rotations in radians at the rigid joint that requires an iterative procedure. This equation comes in the form of: $$ x_i = \frac {Q_ih_i + Q_{i+1}h_{i+1}}{4K} + \frac {C}{K}x_{i-1} + \frac {C}{K}x_{i+1} $$ Where: ## Q ## is the horizontal storey shear ## h ## is the storey height ## K = (6G_i + C_i + C_{i+1}) ## ## G = \frac {I_g}{h} ## ## C...
12K
