I Error on a weighing scale due to wrong size
When weighing a rigid object that overhangs a scale's tray, the measurement error is generally minimal, often estimated at zero unless the object is unevenly distributed or tilting the pan. The shape of the object can affect the measurement; for example, rod-shaped items can be positioned to minimize overhang. Conducting tests by weighing items with and without overhang can help assess precision and identify any variations. It's recommended to repeat measurements multiple times for accuracy. Overall, experimenting with different placements and shapes can provide insights into potential errors in weighing.
cloa513
If you have say a 15 centimetre long piece of rigid plastic and the weighing scale's tray is only 10 centimetres, what is an estimate of the error that introduces in the measurement assuming the weight is still within normal parameters for the weighing scale. I was wondering what the approximate error in general for moderately rigid materials? It happens now and again at work.
I would expect zero, unless the overhanging part is resting on something or the weight distribution is so uneven it's tilting the pan.
What shape are the things you weigh? Can you hold them vertical somehow so they are fully within the pan? For example, if they are rod-shaped they could be placed horizontally across the top of a cup and then nearly-vertically in it. Then you could compare the measured weights with and without an overhang as a test. Remember to repeat each measurement a few times (take everything off the scale and put it back on) to check your precision.
Likes Lord Jestocost
Shape of things- plates.
Hard for you to test, then. The answer is still zero.
Experiment with a test item, offset and hanging over the pan in different directions. Then break it up and weigh it in the pan. How much variation do you see?
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Scalar and vector potentials in Coulomb gauge Assume Coulomb gauge so that $$\nabla \cdot \mathbf{A}=0.\tag{1}$$ The scalar potential ##\phi## is described by Poisson's equation $$\nabla^2 \phi = -\frac{\rho}{\varepsilon_0}\tag{2}$$ which has the instantaneous general solution given by $$\phi(\mathbf{r},t)=\frac{1}{4\pi\varepsilon_0}\int \frac{\rho(\mathbf{r}',t)}{|\mathbf{r}-\mathbf{r}'|}d^3r'.\tag{3}$$ In Coulomb gauge the vector potential ##\mathbf{A}## is given by...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
