- #36
- 46,647
- 23,201
strangerep said:suppose you measure the particle's position to be ##x = x_0##.
You can't. The mathematical operator that would do that is not physically realizable.
strangerep said:By the postulate, the state after the measurement must (supposedly) be the position eigenstate corresponding to eigenvalue ##x=x_0##.
Which is impossible; the mathematical state in question is not physically realizable.
Possibly there is an argument that can be made that applies to operators that are actually physically realizable (perhaps such an argument is in the paywalled paper), but I don't agree that it's just "obvious", since the "obvious" argument you have stated is open to the obvious objections that I have just given.
strangerep said:the system's state post-measurement is not, in general, the eigenstate of the observable that was just measured -- as explained by Ballentine in much more detail in his sect 9.2 et seq.
The argument given there (which I agree with) appears to me to be addressing a different issue: the issue that, since the process of measurement (and indeed more generally any interaction, as Ballentine points out) entangles the measured system with the measuring device, after the measurement neither of those subsystems by itself has any definite state at all: only the joint system containing both measured system and measuring device does. So obviously the measured system can't be in an eigenstate of the measurement operator, since it isn't in any definite state at all.
Ballentine's solution to that problem is to adopt an ensemble interpretation. But that, by itself, doesn't address the "watched pot" issue, because the computation of the joint probability of successive measurement results being the same on a given state, given in section 12.2, is not interpretation-dependent; it's a straightforward application of the math of QM. So it should be valid under the ensemble interpretation. And the handwaving claim that the simple conclusion reached based on this simple computation must be false because "continuous observation does not prevent motion" doesn't help, because that claim is not a claim about ensembles, it's a claim about individual objects. But Ballentine's whole point is supposed to be that QM doesn't tell us about individual objects, it tells us about ensembles.
So no, I don't agree that his claim is just "obvious". Again, possibly these gaps are filled in in the paper that is unfortunately paywalled. But it seems clear to me that there are gaps.
