Essential Supremum Problem: Measurable Positive Functions
  • Thread starter Thread starter johnson123
    Supremum
johnson123
Problem: Show an example of a sequence of measurable positive functions on (0,1) so that
\left\|\underline{lim} f_{n}\right\| < \underline{lim}\left\|f_{n}\right\| for n\rightarrow\infty
My work: I think its just the indicator function I_{[n,n+1]}
Since \left\|\underline{lim} I_{[n,n+1]}\right\|= 0 < \underline{lim}\left\|I_{[n,n+1]}\right\| =1
For some reason I do not feel to confident in my answer, so any comments are welcome.
correction
\left\|\underline{lim} f_{n}\right\|_{\infty} < \underline{lim}\left\|f_{n}\right\|_{\infty} for n\rightarrow\infty
Since \left\|\underline{lim} I_{[n,n+1]}\right\|_{\infty}= 0 < \underline{lim}\left\|I_{[n,n+1]}\right\|_{\infty} =1
That's pretty good. But the domain of the indicator functions isn't (0,1). Can you build a very similar example using functions defined only on (0,1)?
Thanks for the response Dick.
If f_{n}=I_{(\frac{n-1}{n},1)}, then \left\|\underline{lim} I_{(\frac{n-1}{n},1)}\right\|_{\infty}= 0 < \underline{lim}\left\|I_{(\frac{n-1}{n},1)}\right\|_{\infty} =1
Please correct me if I am wrong.
Sure. That's fine. I was thinking of I_(0,1/n), but you can put stuff on the other side of the interval as well.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
