Estimate Instantaneous Velocity
In summary: You have the equation: y(t)=48t−16t2When I plug 48(t)-16(t)^2 into \dfrac{y(2+h)-y(2)}{(2+h)-2}, I don't understand how to do it. Am I actually plugging in 48(t)-16(t)^2 into the y values of the other equation? Something like...y(t)=48t−16t2...or is there a different way to do it?
FritoTaco
132
23
If a ball is thrown into the air with a velocity of 48 ft/s, its height in feet t seconds later is given by y = 48t − 16t2.
(a) Find the average velocity for the time period beginning when t = 2 and lasting for each of the following.
(i) 0.5 seconds
(ii) 0.1 seconds
(iii) 0.05 seconds
(iv) 0.01 seconds
(b) Estimate the instantaneous velocity when t = 2.
[itex]Average Velocity =\dfrac{\triangle y}{\triangle t}[/itex] (Change in position over change in time)
[itex]m=\dfrac{y_{2}-y_{1}}{x_{2}-x_{1}}[/itex]
Set: [itex]t = 2[/itex] and [itex]t = 2 + h[/itex] (let h be the time difference) [itex]\ne 0[/itex]
[itex]t = 2[/itex] is [itex]y_{1},x_{1}[/itex] and [itex]t = 2 + h[/itex] is [itex]y_{2},x_{2}[/itex]
Average Velocity = [itex]\dfrac{y(2+h)-y(2)}{(2+h)-2}[/itex]
Now with [itex]y=48t-16t^2[/itex], we will replace [itex]t[/itex] with [itex]2[/itex] and [itex]2 + h[/itex].
[itex]\dfrac{48(2+h)-16(2+h)^2-[48(2)-16(2)^2)]}{h}[/itex]
[itex]\dfrac{96+48h-16(4+4h+h^2)-96+64}{h}[/itex]
[itex]\dfrac{48h-64-64h-16h^2+64}{h}[/itex]
[itex]\dfrac{-16h^2-16h}{h}[/itex]
[itex]\dfrac{h(-16h-16)}{h}[/itex]
Average Velocity =[itex]-16h-16[/itex]
Then I plug in (i) 0.5 into the equation like this: [itex]-16(0.5)-16=24[/itex]
I do this for the rest of them and get correct answers according to the online "WebAssign" website. Now I'm stuck on (b) "Estimate the instantaneous velocity when t = 2." You can look at my picture, I tried plugging in values near 2 like 2.1 and 2.01, etc, into [itex]y=48t-16t^2[/itex] What am I doing wrong? So as I get closer to 2 I get closer to the slope of 31.999 which then you make an educated guess (by rounding) and get 32. But this is wrong. I don't know why? Also, I heard there is another method for finding average velocity, my book doesn't have it--anyone know it? Much appreciation.
(i) 0.5 seconds
(ii) 0.1 seconds
(iii) 0.05 seconds
(iv) 0.01 seconds
For the instantaneous velocity near t = 2, look at the change in position divided by the change in time.
Look at ##\frac{y(2 + h) - y(2)}{2 + h - 2}##, for some values of h that are close to 0, say h = .1, h = .01, h = .001.
You should get a value close to -16 ft/sec.
Likes FritoTaco
My teacher also said use values like 0.1, 0.01, etc. Why? I don't get why we're using those values? Also, how do we make the equation where we can plug in those values? from using [itex]\dfrac{y(2+h)-y(2)}{(2+h)-(2)}[/itex]
Because you want the time interval to be very short so as to get a closer estimate of the instantaneous velocity.
You have the equation: ##y(t) = 48t - 16t^2##
Likes FritoTaco
This is where I don't understand. It says find instantaneous velocity when t = 2. Okay, so don't we want to use values close to 2? Like 2.1, 2.01. So if it was like, "find instantaneous velocity closer to when t = 5", would I still use 0.1, 0.01, etc? Because that means we are 0.1 from 5 or 0.01 from 5?
When I plug [itex]48(t)-16(t)^2[/itex] into [itex]\dfrac{y(2+h)-y(2)}{(2+h)-2}[/itex], I don't understand how to do it. Am I actually plugging in [itex]48(t)-16(t)^2[/itex] into the y values of the other equation? Something like this:
[itex]\dfrac{48t-16t^2(2+h)-48t-16t^2(2)}{2+h-2}[/itex]? Then distribute and simplify it down more?
Yes. If h = .01, then 2 + h = 2 + .01 = 2.01
No, you are "plugging in" 2 + h and 2, respectively, into your height function y(t) = 48t - 16t2
For y(2 + h), replace t in your formula with 2 + h.
For y(2), replace t with 2.
Then simplify the result.
Likes FritoTaco
[itex]48(2+h)-16(2)^2[/itex]
[itex]96+48h-64[/itex]
[itex]48h-32[/itex]
Am I doing this right?
I don't know what you're doing above.
[itex]48h-32[/itex]
No. This is what you should be evaluating: ##\frac{y(2+h)-y(2)}{(2+h)-2}##, using ##y(t) = 48t - 16t^2##. The quotient here gives you the average speed between time t = 2 + h and time t = 2.
Edit: Fixed a typo I had in the y(t) formula.
Likes FritoTaco
Mark44 said:
No. This is what you should be evaluating: y(2+h)−y(2)(2+h)−2y(2+h)−y(2)(2+h)−2\frac{y(2+h)-y(2)}{(2+h)-2}, using y(t)=48t−32t2y(t)=48t−32t2y(t) = 48t - 32t^2. The quotient here gives you the average speed between time t = 2 + h and time t = 2.
How did you get [itex]y(t)=48t-32t^2[/itex]?
Also, in above when you said "For y(2 + h), replace t in your formula with 2 + h. For y(2), replace t with 2." Isn't that what I did and got the [itex]48h - 32[/itex]?
I miswrote 32t2 instead of 16t2. I have fixed my typo.
Whatever you did isn't right. y(2 + h) gives you two terms, and y(2) also gives you two terms. Also, you have 2 + h - 2 in the denominator.
Likes FritoTaco
Let's back up a few steps. You need to evaluate ##\frac{y(2 + h) - y(2)}{2 + h - 2}##, using ##y(t) = 48t - 16t^2##.
What do you get for y(2 + h)?
What do you get for y(2)?
Likes FritoTaco
Am I placing [itex]48t-16t^2[/itex] into the y part of both [itex]y(2+h)[/itex] and [itex]y(2)[/itex]?
Like this maybe:
[itex]\dfrac{48(2+h)-16(2+h)^2-[48(2)-16(2)^2]}{(2+h)-2}[/itex]
[itex]\dfrac{96+48h-16(h^2+4h+4)-96+64}{(2+h)-2}[/itex]
[itex]\dfrac{96+48h-16h^2-64h-64-96+64}{(2+h)-2}[/itex]
[itex]\dfrac{-16h^2-16h}{(2+h)-2}[/itex]
I'm pretty sure something isn't right but I gave it a go here.
Like this maybe:
This is correct, but you should simplify the denominator.
When you've done that, estimate the velocity at a few times close to 2 sec., such as 2.1 (h = .1), 2.01 (h = .01), and however more you need to do.
Likes FritoTaco
Will it just be [itex]\dfrac{-16h^2-16h}{h}[/itex]?
And simplfy that...
Likes FritoTaco
Like this:
[itex]\dfrac{-16h(h+1)}{h}[/itex] Factor
[itex]16(h+1)[/itex] Cancel out the h
FritoTaco said:
Like this:
Where did the minus sign go?
When you get that straigtened out, pick a few (small) values of h, as described in parts i) through iv) of the first post, and then estimate the velocity at t = 2 seconds.
Likes FritoTaco
Oh, I forgot about that. It should've been there as [itex]-16(h+1)[/itex]
i.)0.5
[itex]-16(0.5+1) = -24 ft/s[/itex]​
ii.)0.1
[itex]-16(0.1+1) = -17.6 ft/s[/itex]​
iii.)0.05
[itex]-16(0.05+1) = -16.8 ft/s[/itex]​
iv.)0.01
[itex]-16(0.01+1) = 1-6.16 ft/s[/itex]​
b.) Estimate the instantaneous velocity when t = 2.
[itex]-16(0.01+1) = -16.16 ft/s[/itex]
[itex]-16(0.001+1) = -16.08 ft/s[/itex]
Estimate: [itex]-16 ft/s[/itex].
I entered that in and got it right! Thank you very much for your help!
FritoTaco said:
iv.)0.01
Surely, you mean -16.16 ft/sec
Likes FritoTaco
Oh, oops. Yeah, -16.16ft/s.
FAQ: Estimate Instantaneous Velocity
What is instantaneous velocity?
Instantaneous velocity is the velocity of an object at a specific moment in time. It is the rate at which an object is changing its position at that moment, and is typically measured in meters per second (m/s).
How is instantaneous velocity different from average velocity?
Instantaneous velocity is calculated at a specific moment in time, while average velocity is calculated over a period of time. Average velocity takes into account the total distance traveled and the total time taken, while instantaneous velocity only considers the velocity at that particular moment.
How is instantaneous velocity calculated?
Instantaneous velocity can be calculated by taking the derivative of the position function with respect to time. This can be represented as the limit of the average velocity as the time interval approaches zero.
Can instantaneous velocity be negative?
Yes, instantaneous velocity can be negative. This indicates that the object is moving in the opposite direction of its positive velocity. For example, if a car is traveling forward with a velocity of 20 m/s and then suddenly stops, its instantaneous velocity at that moment would be -20 m/s.
How is instantaneous velocity used in real-world applications?
Instantaneous velocity is used in various fields, such as physics, engineering, and sports. In physics, it is used to analyze the motion of objects and understand their acceleration. In engineering, it is used to design machines and structures that require precise motion control. In sports, it is used to track the performance of athletes and analyze their movements.
