Estimated spring back while bending 5052 aluminum
  • Thread starter Thread starter Ryoko
    Bending
When bending 5052-H32 aluminum to a 90-degree angle with a 1T bend radius, an estimated spring back of about 3 degrees is anticipated. Conducting an experiment with a simple 90° die and measuring the resulting angle can provide a more accurate assessment of spring back. If existing dies from a previous job are available, they can also be utilized for testing. Applying sufficient pressure during the bending process may eliminate spring back by coining the metal. The project involves creating a 1/4" U-channel for edging trim, as off-the-shelf options are unsuitable.
Ryoko
I need to make a set of dies to roll form a 1" wide strip of 5052-H32 0.063" aluminum for a home project. The bend radius is 1T (0.063") and I want to bend it to 90 degrees. My understanding is that this type of aluminum is a bit springy. So if someone could give an estimate on how much spring back to expect it would be much appreciated.
That is a tight bend. My guess would be about 3°.
An experiment would help.
Make a simple 90° die and press a sample.
Measure the resulting angle to find the spring-back.
If there are dies for the rolls, available from a previous job, do the experiment with those.
If you press hard enough, you will coin the metal and there will be no spring back.
Yes, it's a pretty steep bend. I need to make a 1/4" U-channel for use as an edging trim piece. So I'll be forming both sides of a flat strip. I'd use off-the-shelf trim, but they are either the wrong material or have sharp corners which is not desired for this application. I am going to make a set of rollers on my mighty Unimat lathe. Woot! I only need to make a couple of pieces.
Here's a video by “driving 4 answers” who seems to me to be well versed on the details of Internal Combustion engines. The video does cover something that's a bit shrouded in 'conspiracy theory', and he touches on that, but of course for phys.org, I'm only interested in the actual science involved. He analyzes the claim of achieving 100 mpg with a 427 cubic inch V8 1970 Ford Galaxy in 1977. Only the fuel supply system was modified. I was surprised that he feels the claim could have been...
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
