Estimating Mass of Particules in Earth's Magnetosphere
  • Thread starter Thread starter Cerdocyon
    Mass
To estimate the mass of particles in Earth's magnetosphere up to 100 times Earth's radius, one must first calculate the volume of that space using the Earth's radius and geometric formulas. The average density of protons is given as 10 protons/cm³, and the mass of a proton is approximately 1.67 x 10^-27 kg. By determining the total volume and applying the density, the total mass can be calculated. It is important to account for any excluded areas within the volume to ensure accuracy. This approach provides a straightforward method to solve the problem.
Cerdocyon
Hello,
The problem is quite simple.
Estimate the mass of particules that contains the Earth's magnetosphere up to a distance of 100 times erath's radius (In the shadow cone of earth) and also up to the break point or stopping point of the side of the sun.The solar activity is at its minimum and the average density is 10 protons/cm³.
Thank you.
This looks like homework. What did you do so far?
Where did you run into problems?
Well indeed it's a homework and i didn't get anywhere i can't figure out how to calculate the mass of particules.
You have a particle density. Do you know the mass of a proton?
Do you know some relation between density in a volume and total mass? What do you need for that?
Well, the mass of a proton is 1.67*10^-27 and i know that density equals volume divided by mass but i don't have a volume and i certainly don't see a way how to calculate it and furthermore there are distances which i don't knowwhat will be the use of them.
Cerdocyon said:
Hello,
Thank you.
The volume you need is described. First look up the radius of the Earth. Multiply that by 100. Then use geometry to calculate the volume. If areas are excluded work out the volume of the excluded regions
and subtract those from the total volume. Your given the average density so it should be easy from there
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
Thread 'How to find the pH of a galvanic cell (MIT OCW problem set)'
This is the final problem in this problem set from MIT OCW. Here is what I did to try to solve it The table cited in the problem is below We can easily spot the two redox couples that are in the electrochemical cell we are given. The hydrogen-based electrode has standard potential zero, and the silver-based electrode has standard potential 0.22. Thus, the hydrogen electrode, with the lower potential, is the reducing agent (ie, it is where oxidation happens) and is the anode. Electrons...
