Estimating Time Since Formation of U 235 and U 238
  • Thread starter Thread starter kel
    Formation Time
The discussion revolves around estimating the time since the formation of U-235 and U-238 based on their decay rates and current ratio. The original poster calculated the time to be approximately 8.69 billion years using the decay equation and half-lives of the isotopes. Respondents confirmed the method was correct but noted a potential confusion regarding the half-lives provided, which differ from standard values. A more accurate calculation using the correct half-lives suggests a formation time of about 6.74 billion years. The conversation emphasizes the importance of verifying initial conditions and equations in decay calculations.
kel
Hi, I've worked this out (I think) but would appreciate someone xhecking over my method.
U 235 and U 238 found in ratio of 7.3E-3 to 1, but thought to have been produced equally (ie equal quantities)
half lives are 1.03E9 and 6.49E9 respectively.
Estimate time since formation
Decay equation: N(t) = No e^(-wt) (used w for lambda here)
As No is the same for both
Ln (N(t) / e^(-w1.t)) = Ln No
Ln N(t) + w1.t = Ln N(t) + w2.t
w1 = ln2 / 1.03E-9 = 6.729E-10
w2 = ln2 / 6.49E9 = 1.068E-10
Put these into above equ and re-arranging
ln (7.3E-3) - ln(1) = (t (6.729E-10)-(1.068E-10))
giving
t = (ln (7.3E-3) - ln(1)) / ((6.729E-10)-(1.068E-10))
which I work out to be 8.69E9 years.
I'm not quite sure if this is correct, but any advice would be appreciated.
Thanks
Hi, your method is correct except a missed symbol in equation:
ln (7.3E-3) - ln(1) = t((6.729E-10)-(1.068E-10))
but it doesn't matter. If no calculation mistake, the answer is a correct one.
If you mean that I have missed 't' out, then that is because both w1 and w2 are being multipled by t, so I factored it out
giving
Thanks
Yes, it's right.
Notice you can always double check by plugging in the initial equation!
I am not clear on your units. The half life of U238 is 4.51x10^9 years. The half life of U235 is 7.04x10^8 years.
N/N0 = 1/2 =e^{\omega_{238}(4.51 x 10^9)} so
\omega_{238} = \ln{.5}/(4.51 x 10^9) = -1.5x10^{-10}
Similarly:
\omega_{235} = \ln{.5}/(7.04 x 10^8) = -9.8x10^{-10}
So if they started out in the same proportion after a SuperNova, the SuperNova occurred about:
.0073 = e^{-\omega_{235}t}/e^{-\omega_{238}t} = e^{(\omega_{238}-\omega_{235})t}
t = \ln{.0073}/(\omega_{238}-\omega_{235}) = 4.92/(7.3x10^{-10}) = 6.74 x 10^9 \text{years}
AM
Similarly:
AM
Good observation. It looks like the OP is being given inverse decay rates rather than half-lives. kel would be advised to carefully check the wording of the question.
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
