I Estimating Vertical Wind Speeds: T_a, T_s, & P_a
Estimating vertical wind speeds using data from an automatic weather station, including 2m air temperature, surface temperature, and air pressure, is complex. Key concepts like eddy covariance and the Bowen ratio energy balance are essential, as they relate vertical air movement to evaporation. The hypsometric equation can potentially be used to calculate surface pressure, which may help in relating pressure differences to vertical velocity. A recommended resource for further understanding is the book "Evaporation Into the Atmosphere" by W. Brutseart. Overall, additional variables and a deeper understanding of atmospheric dynamics are necessary for accurate estimations.
jones1234
TL;DR Summary
Calculate vertical wind speed based upon temperature difference
Hi all,
I have some data from an automatic weather station, with recordings of both 2m air temperature and 2m air pressure and also the surface temperature. Is it possible to estimate vertical wind speeds between the AWS and the surface based upon this data? Imagine T_a = 15 degrees and T_s = 30 degrees and P_a = 670 hPa. If not, which other variables do I need?
Thanks.
It's more complicated than that. I suggest the these search terms to learn more: eddy covariance and Bowen ratio energy balance. These search terms are mostly about evaporation of surface water, and vertical air movement is closely tied to evaporation. A good book on the subject is Evaporation Into the Atmosphere: Theory, History, and Applications, by W. Brutseart (1982). An oldie, but goody, and it's still in print because it is the standard reference in that field: https://www.amazon.com/dp/9027712476/?tag=pfamazon01-20.
Likes pbuk, berkeman, anorlunda and 1 other person
Thanks for the answer! I was thinking maybe to calculate the pressure at the surface with the hypsometric equation and then relate the pressure difference to a vertical velocity... is this also possible?
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Scalar and vector potentials in Coulomb gauge Assume Coulomb gauge so that $$\nabla \cdot \mathbf{A}=0.\tag{1}$$ The scalar potential ##\phi## is described by Poisson's equation $$\nabla^2 \phi = -\frac{\rho}{\varepsilon_0}\tag{2}$$ which has the instantaneous general solution given by $$\phi(\mathbf{r},t)=\frac{1}{4\pi\varepsilon_0}\int \frac{\rho(\mathbf{r}',t)}{|\mathbf{r}-\mathbf{r}'|}d^3r'.\tag{3}$$ In Coulomb gauge the vector potential ##\mathbf{A}## is given by...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
