MHB Euler Lagrange equation of motion
The discussion centers on the challenges of applying the Euler-Lagrange equation when the potential energy in the Lagrangian depends on the absolute value of the generalized coordinate x, particularly at x=0 where the derivative becomes undefined. Participants suggest that this indicates a special condition in the system, possibly treating x=0 as a singularity and requiring separate solutions for x>0 and x<0. The Weierstrass-Erdmann Corner Condition is mentioned as a potential tool for handling the discontinuity. The conversation emphasizes that if the Lagrangian is valid only outside a certain range, then x=0 may not be a physical solution. Overall, the need for careful consideration of the system's behavior around x=0 is highlighted.
skate_nerd
I have a system with one generalized coordinate, x. In the potential energy part of the lagrangian, I have some constants multiplied by the absolute value of x. That is the only x dependence the lagrangian has, so when I take the partial derivative of the lagrangian with respect to x (to get the euler lagrange differential equation), I get a derivative that is undefined at x=0. Is there anything that I am supposed to do about this? Or do I just leave the derivative (x/|x|) and go on with writing the diff. eq?
Also, let it be known that x is a function of t (x(t)).
I think this may change things but I'm not sure. Why would the partial x derivative of |x(t)| be any different then the direct x derivative of |x(t)|?
Mathematics news on Phys.org
Well, you'll need to treat the corner carefully. The Weierstrass-Erdmann Corner Condition might be useful. Otherwise, I would proceed with the usual calculations.
$x$ is always $x(t)$. You don't need to worry about $t$ showing up in the Lagrangian if it's inside the function $x$.
It means that your system explodes if it passes through x=0.
Physically that is not possible, so that suggests there is something special going on with your lagrangian.
Perhaps x=0 is outside of the range in which your lagrangian is valid?
Where is this step function coming from?
Something like that might happen if you model the gravity of an object with mass M with $$V=-\frac {GM}{x}$$.
It is only valid if you are outside the object.
Thanks for the responses Ackbach + I Like Serena.
@I Like Serena, you're saying I have a step function, so do I need to treat my whole solution like one? With two specific solutions, one for x>0 and x<0, and one for x=0?
Looks like it.
Presumably you won't have a solution for x=0 other than that the system behaves like a singularity in space and time.
Can't really say much more without more information.
Thanks. I think that's probably all I'll need to know. I've got the info.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
