Euler-Lagrange Equations for geodesics
The discussion focuses on deriving the Euler-Lagrange equations for geodesics using the Lagrange function related to the metric tensor. Participants calculate both sides of the Euler-Lagrange equation, noting the need for careful index management and the inclusion of missing terms from the metric's derivatives. The conversation emphasizes the importance of the Christoffel symbols in relating the geodesic equation to the metric's properties. Participants clarify that the product rule must be applied correctly to account for the derivatives of the metric, which ultimately leads to the correct form of the geodesic equation. The exchange highlights the complexities involved in ensuring all terms are accounted for in the derivation process.
Pentaquark5
The Lagrange Function corresponding to a geodesic is $$\mathcal{L}(x^\mu,\dot{x}^\nu)=\frac{1}{2}g_{\alpha \beta}(x^\mu)\dot{x}^\alpha \dot{x}^\beta$$
Calculate the Euler-Lagrange equations
The Euler Lagrange equations are $$\frac{\mathrm{d}}{\mathrm{d}s} \left( \frac{\partial \mathcal{L}}{\partial \dot{x}^\mu} \right) =\frac{\partial \mathcal{L}}{\partial x^\mu}$$
The solution should be
$$\frac{\mathrm{d}^2 x^\mu}{\mathrm{d}s^2}+\Gamma^\mu_{\;\;\alpha \beta} \frac{\mathrm{d}x^\alpha}{\mathrm{d}s} \frac{\mathrm{d}x^\beta}{\mathrm{d}s}=0$$
Calculate LHS:
$$\frac{\partial \mathcal{L}}{\partial \dot{x}^\mu}=\frac{1}{2}\dot{x}^\beta (g_{\mu\beta}+g_{\beta\mu})=\dot{x}^\beta g_{\mu \beta}$$
$$\frac{\mathrm{d}}{\mathrm{d}s} \left( \frac{\partial \mathcal{L}}{\partial \dot{x}^\mu} \right)=\frac{\mathrm{d}}{\mathrm{d}s} \left(\dot{x}^\beta g_{\mu \beta}\right)=\ddot{x}^\beta g_{\mu\beta}$$
Calculate RHS:
$$\frac{\partial \mathcal{L}}{\partial x^\mu}=\frac{1}{2} \partial_m g_{\alpha \beta}(x^\mu)\dot{x}^\alpha\dot{x}^\beta$$Equating and multiplying with ##g^{kl}##:
$$ \ddot{x}^\beta=\frac{1}{2} g^{\mu \beta} \partial_m g_{\alpha \beta}(x^\mu)\dot{x}^\alpha\dot{x}^\beta $$This kind of looks like the definition of the Christoffel Symbol that I need, however two derivations of the metric are missing. Where did I go wrong?
Thanks
You did not go wrong. I suggest you check what the missing terms are given that they are contracted with the ##\dot x^\mu##.
Edit: Note that what you compute with the EL is the affinely parametrised curve that minimises the distance. This is the same as the geodesic only if the connection is the Levi-Civita connection.
Ok, I just realized my indecess are off.
$$\ddot{x}^\beta \underbrace{g^{kl}g_{\mu\beta}}_{\delta^k_{\;\mu} \delta^l_{\; \beta}}=\frac{1}{2} g^{kl} \partial_\mu g_{\alpha \beta}(x^\mu)\dot{x}^\alpha \dot{x}^\beta$$
$$ \ddot{x}^l = \frac{1}{2} g^{kl} \partial_\mu g_{\alpha \beta}(x^\mu)\dot{x}^\alpha \dot{x}^\beta$$
However, that is a problem, as I would need the ##k## index to appear in the ## \partial_\mu g_{\alpha \beta} ## term, wouldn't I?
Then, I'm still missing some terms along the lines of ## \partial_\alpha g_{k \mu} - \partial_k g_{\mu \alpha} ##, and the signs are all wrong.
I really don't see how to get there!
Ignore what I said in #2. I had some more time to read your post more carefully.
I suggest you drop the argument of the metric because it seems that its index is confusing you (it is not an actual index in the equation, it is just telling you that the metric depends on the position, which you should already know). In addition, this is not correct:
Pentaquark5 said:
$$\underbrace{g^{kl}g_{\mu\beta}}_{\delta^k_{\;\mu} \delta^l_{\; \beta}}$$
What you are looking for is to contract one of the indices of the inverse metric with the free index of the metric, i.e.,
g^{k\beta} g_{\mu\beta} = \delta^k_\beta.
Then look at the Christoffel symbols of the Levi-Civita connection
\Gamma_{\mu\nu}^\lambda = \frac{1}{2} g^{\lambda\rho} (\partial_\mu g_{\rho\nu} + \partial_\nu g_{\mu\rho} - \partial_{\rho}g_{\mu\nu}).
What happens when you insert this into the geodesic equation
(\nabla_{\dot\gamma} \dot\gamma)^\mu = \ddot{x}^\mu + \Gamma_{\alpha\beta}^\mu \dot x^\alpha \dot x^\beta = 0?
Checking it closer, you are actually missing terms on the LHS. Consider this step more carefully:
In addition, in this step on the RHS
suddenly an ##m## and a ##\mu## appeared that are unmatched on the LHS, they should be the same (and again, you would probably do better to drop writing out the index on the argument of the metric, it is just confusing you). Also, your index ##\beta## appears three times in the RHS and only once on the LHS. Probably you should use a different index in the inverse metric that you are multiplying by not to confuse the indices.
Thanks! I think I get it now!
Ok, sorry, but I still don't get it.
When you refer to missing terms, I assume you mean the product rule in the following equation?$$\frac{\mathrm{d}}{\mathrm{d}s} \left( \frac{\partial \mathcal{L}}{\partial \dot{x}^\mu} \right)=\frac{\mathrm{d}}{\mathrm{d}s} \left(\dot{x}^\beta g_{\mu \beta}\right)=\ddot{x}^\beta g_{\mu\beta}+\dot{x}^\beta \frac{\mathrm{d}}{\mathrm{d}s} g_{\mu \beta}$$
I really don't know what do do with ##\frac{\mathrm{d}}{\mathrm{d}s} g_{\mu \beta}##. Doesn't that bring me even further from the required form?
And I also can't seem to work out how inserting the Christoffel symbol in terms of the metric into the equation helps me.
No, it will bring you closer. Use the chain rule:
$$\frac{d}{ds} X ~=~ X,_\nu \, \dot x^\nu $$
