Eulerian velocities to Lagrangian velocities
  • Thread starter Thread starter paccali
    Lagrangian
paccali
Eulerian velocity: V_{1}=-z_{1}^{2}
V_{1}=\frac{dz_{1}}{dt}
z_{1}(t=0)=x_{1}
This is supposed to become the Lagrangian velocity of:
z_{1}=\frac{x_{1}}{1+tx_{1}}
I don't understand how to take the Eulerian velocity and transform it to Lagrangian.
\frac{dz_{1}}{dt}+z_{1}^{2}=0
After this, I don't know how to take this and move forward.
I've been working the problem for a day, and I still can't get any closer. I can take Lagrangian and transform it to Eulerian, but I don't know how to do the reverse. TJ Chung's General Continuum Mechanics book is poorly developed for examples and proofs.
This equation is separable, since it can be rewritten as
-\frac{dz_{1}}{z_{1}^{2}}=dt.
You can integrate both sides and fix the integration constant with
z_{1}(t=0)=x_{1}.
Nevermind, I figured out how to solve the problem using my old differential equations textbook. In case someone is curious, here's what I did:
I rearranged the terms so that like terms were on the same side:
\frac{dz_{1}}{dt}=-z_{1}^{2}
\frac{dz_{1}}{-z_{1}^{2}}=dt
I then integrated each side:
\int -\frac{1}{z_{1}^{2}}dz=\int dt
\frac{1}{z_{1}}+C_{1}=t+C_{2}
Since both sides had constants, I dropped one, and I then used the initial condition of z_{1}(t=0)=x_{1} to solve for C
\frac{1}{z_{1}}+C=t
\frac{1}{z_{1}}=t-C
z_{1}=\frac{1}{t-C}
z_{1}(0)=x_{1}=\frac{1}{0-C}
C=-\frac{1}{x_{1}}
I plugged in C above and got this equation for Lagrangian position:
z_{1}=\frac{1}{t+\frac{1}{x_{1}}}=\frac{x_{1}}{1+tx_{1}}
I just found what I did wrong, but thanks for the help nonetheless.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
