MHB Evaluate ⌊ 1/a_1+1/a_2+....+1/a_{2008} ⌋
  • Thread starter Thread starter juantheron
The sequence \( a_n \) is defined recursively with \( a_1 = \frac{1}{3} \) and \( a_{k+1} = a_k^2 + a_k \). The sum \( S = \sum_{k=1}^{2008} \frac{1}{a_k} \) is evaluated, with initial terms calculated to show \( S(5) = 8.2182 \). An upper bound for the remaining terms \( T(6) < 0.1708 \) leads to the conclusion that \( S < 8.3890 \). Consequently, it is established that \( \lfloor S \rfloor = 8 \). The rapid growth of the sequence ensures that the sum remains bounded between 8 and 9.
juantheron
Consider the sequence $a_{n}$ given by $\displaystyle a_{1} = \frac{1}{3}$ and $\displaystyle a_{k+1}=a^2_{k}+a_{k}$ for $k\geq 2$and Let $\displaystyle S = \frac{1}{a_{1}}+\frac{1}{a_{2}}+\cdots \cdots +\frac{1}{a_{2008}}$. Then $\lfloor S \rfloor $ is
Mathematics news on Phys.org
[sp]
Note: I assume that the recurrence holds for $k\ge\bf1$.
Let us write $ b_n = \dfrac{1}{a_n}$, $S(n) = \sum_{k=1}^nb_k$, and $T(n) = \sum_{k=n}^{2008}b_k$. As $a_{n+1} > a_n^2$, we have $b_{n+1} < b_n^2$. If $b_n < 1$, comparison with the geometric progression of ratio $b_n$ gives:
$$T(n) < \frac{b_n}{1-b_n}.$$
We compute now the first few terms of the series:
\begin{array}{c|c|c|c}
n&a_n&b_n&S(n)\\
\hline
1&0.3333&3.0000&3.0000\\
2&0.4444&2.2500&5.2500\\
3&0.6420&1.5577&6.8077\\
4&1.0541&0.9487&7.7564\\
5&2.1653&0.4618&8.2182\\
6&6.8536&0.1459&8.3641\\
\end{array}
Using the remark above, we find $T(6) < \dfrac{b_6}{1-b_6} = 0.1708$. This shows that:
S(5) = 8.2182 < S = S(2008) = S(5) + T(6) < 8.2182 + 0.1708 = 8.3890
and therefore $\lfloor S\rfloor = 8$.
[/sp]
[sp]$\displaystyle x_{1} = \frac{1}{3}.$
$\displaystyle x_2=\dfrac{4}{9}$.
$\displaystyle x_3=\dfrac{52}{81}\in\left(\dfrac{5}{8},\dfrac{2}{3}\right)$.$\displaystyle x_4>\left(\dfrac{5}{8}\right)^2+\dfrac{5}{8}=\dfrac{65}{64}>1$;
$\displaystyle x_4<\left(\dfrac{2}{3}\right)^2+\dfrac{2}{3}=\dfrac{10}{9}$;$x_5>1^2+1=2$;
$\displaystyle x_5<\left(\dfrac{10}{9}\right)^2+\dfrac{10}{9}=\dfrac{190}{81}<\dfrac{12}{5}$;$x_6>2^2+2=6$;$\displaystyle \sum^{2008}_{k=1}\dfrac{1}{x_{k}}>\sum^{5}_{k=1}\dfrac{1}{x_{k}}>+3+\dfrac{9}{4}+\dfrac{3}{2}+\dfrac{9}{10}+\dfrac{5}{12}>8$.Beginning from $x_6$, the sequence $x_n$ is growing very fast.
For $k\ge 6: x_k>6^{k-5}$.
$\displaystyle \sum_{k=6}^{2008}\dfrac{1}{x_k}<\sum_{m=1}^{+\infty}\dfrac{1}{6^m}=\dfrac{1}{5}$.Results: $\displaystyle \sum^{2008}_{k=2}\dfrac{1}{x_{k}}=\sum^{5}_{k=1}\dfrac{1}{x_{k}}+\sum^{2008}_{k=6}\dfrac{1}{x_{k}}<+3+\dfrac{9}{4}+\dfrac{8}{5}+1+\dfrac{1}{2}+\dfrac{1}{5}<9$.So we have $\displaystyle8<\sum^{2008}_{k=1}\dfrac{1}{x_{k}}<9\Longrightarrow\left\lfloor \sum^{2008}_{k=1}\dfrac{1}{x_{k}}\right\rfloor=8$[/sp]
Here is a little puzzle from the book 100 Geometric Games by Pierre Berloquin. The side of a small square is one meter long and the side of a larger square one and a half meters long. One vertex of the large square is at the center of the small square. The side of the large square cuts two sides of the small square into one- third parts and two-thirds parts. What is the area where the squares overlap?
  • · Replies 20 ·
