Evaluate Integral with 3-x^4: Solution & Steps
  • MHB
  • Thread starter karush
  • Tags
    Integral
In summary, to evaluate the integral $\displaystyle \int \frac{x}{\sqrt{3-x^4}} dx$, you can use the substitution $u=x^2$ and then solve the resulting standard integral form $\displaystyle \frac{1}{2} \int \frac{1}{\sqrt{3-u^2}} du$. This can then be simplified to $\displaystyle \frac{1}{2} \sin^{-1}\left(\frac{\sqrt{3}x^2}{3}\right) + C$.
karush
MHB
3,269
\displaystyle
\int
it looks like a trig substation but with x in the denominator I did this
\displaystyle
\int
\left(3-x^4\right)^{-1/2}x\text{ dx}
with the $x/dx$ of ${3-x^4}=4x^3$ I couldn't see how to get how to get this to work
but the calc on this gives the right ans
I think you can transform this into a standard integral form. If you use the substitution $u=x^2$ then $du=2xdx$ and the integral becomes:
\(\displaystyle \frac{1}{2}\int \frac{1}{\sqrt{3-u^2}}du\)
well that sure looks better
will have to get back to this I ran out of time
MHB is really a great help.;)
$\displaystyle
\frac{1}{2}
\frac{1}{2}
\left[\sin^{-1}\left(\frac{\sqrt{3}u}{3}\right)\right]
replacing $u$ with $x^2$
$\displaystyle
\frac{1}{2}
FAQ: Evaluate Integral with 3-x^4: Solution & Steps
How do I evaluate an integral with 3-x^4?
To evaluate an integral with 3-x^4, you can follow these steps:
  1. First, rewrite the integral as the sum or difference of simpler integrals.
  2. Then, use the power rule to integrate each term separately.
  3. If necessary, use substitution or integration by parts to simplify the integrals.
  4. Finally, evaluate the resulting integrals and combine the solutions to get the final answer.
What is the solution to the integral with 3-x^4?
The solution to the integral with 3-x^4 depends on the limits of integration. You will need to follow the steps for evaluating the integral and plug in the limits to get the final answer.
Is there a shortcut to evaluating integrals with 3-x^4?
Unfortunately, there is no shortcut to evaluating integrals with 3-x^4. Each integral will have its own unique solution and will require following the steps for integration.
Can I use a calculator to evaluate the integral with 3-x^4?
Yes, you can use a calculator to evaluate the integral with 3-x^4. However, it is still important to understand the steps and concepts behind integration in order to accurately interpret the calculator's solution.
What are some common mistakes to avoid when evaluating integrals with 3-x^4?
Some common mistakes to avoid when evaluating integrals with 3-x^4 include forgetting to apply the power rule, making errors in algebraic simplification, and forgetting to incorporate the limits of integration into the final answer. It is important to double check your work and carefully follow the steps for integration to avoid these mistakes.
