- #211
Jilang
- 1,116
- 72
And A determines the basis and so in part determines a.
So? What is your point?Jilang said:And A determines the basis and so in part determines a.
Please see post #206.mikeyork said:So? What is your point?
Measuring the center of mass of a macroscopic body, or measuring the mass or the total energy of a brick of iron. In each case the measurement produces a single number, and for the corresponding ##A## the value equals <A> to several significant digits.mikeyork said:What kind of macroscopic measurement do you have in mind?
Whereas my point (and the point of the authors of the papers under discussion here) is that whenever one makes a macroscopic measurement one measures <A>.mikeyork said:but my point is that we don't measure <A>.
The SG experiment can be understood without any semiclassical approximation (at least if you admit some simple numerics to solve the time-dependent Schrödinger equation). It's of course clear that the final measurement via looking at a CCD screen (or in the original Frankfurt setup a photoplate using sulphur-reach cigars for better contrast ;-)) involves macroscopic measurement devices.A. Neumaier said:Measuring the center of mass of a macroscopic body, or measuring the mass or the total energy of a brick of iron. In each case the measurement produces a single number, and for the corresponding ##A## the value equals <A> to several significant digits.
Even in a Stern-Gerlach measurement what one actually measures is a macroscopic spot on the screen, From such measurements one deduces theoretically - using a semiclassical model calculation - the values of the angular momentum of the silver atoms and arrives at an eigenvalue of the microscopic observable ##A##. The papers under discussion show how (in a similar, slightly idealized experiment to make it tractable theoretically) statistical mechanics (with the alternative interpretation repeatedly discussed by me in this thread) produces the correct predictions, namely those that were postulated (rather than deduced) by Born's rule.
In that case, how is ##<A>## different from ##<a>##? (See my post #210.)A. Neumaier said:Measuring the center of mass of a macroscopic body, or measuring the mass or the total energy of a brick of iron. In each case the measurement produces a single number, and for the corresponding ##A## the value equals <A> to several significant digits.
Because measurement is a complicated statistical mechanics process that should not enter the foundations of quantum mechanics - just as it doesn't enter the foundations of classical mechanics. Born's rule should be a consequence of good foundations rather than a postulate that is part of (in the opinion of many physicists problematic) foundations.vanhees71 said:What I still don't understand is, why you need an alternative interpretation of (quantum) statistical mechanics.
Well, engineers disagree.vanhees71 said:a single measurement is as good as doing no measurement, as you learn in the freshman introductory lab on day 1
I don't know what a is, hence not what <a> should mean.mikeyork said:In that case, how is ##<A>## different from ##<a>##? (See my post #210.
Because all measurements are derived by computations or interpretation from macroscopic measurements. So the latter are the basic objects without which the former cannot even be found. Moreover, macroscopic measurements give meaningful results even without repetition. Hence macroscopic objects have a more realistic nature than microscopic ones.mikeyork said:How is the distinction between macroscopic and microscopic relevant?
This is a typical misunderstanding of many theoretical physicists. Physics is all about measurements! You cannot even do good old classical Newtonian mechanics without defining observables first, and observables are defined by (equivalence classes) of measurement procedures. For Newtonian mechanics you need to quantitatively define time, length, and mass as the fundamental quantities upon which the entire edifice is built.A. Neumaier said:Because measurement is a complicated statistical mechanics process that should not enter the foundations of quantum mechanics - just as it doesn't enter the foundations of classical mechanics. Born's rule should be a consequence of good foundations rather than a postulate that is part of (in the opinion of many physicists problematic) foundations.
That measuring a spot on a screen tells us anything about the state of a silver atom is something that needs to be proved from the dynamics of quantum mechanics rather than postulated at the outset.
At least this is the opinion of the authors whose work is discussed in this thread, and it is also my opinion, having spent before many years on trying to understand the foundations until I realized that.
I hope very much, using a lot of products by engineers, that they do not disagree, and as far as I can say from what's taught in the engineering faculties around the world, they indeed don't!A. Neumaier said:Well, engineers disagree.
Most things in everyday practice (which is the origin of the majority of macroscopic measurements made) are measured only once or twice, with very informative results.
Only measurements that are very noisy need many repetitions - and even then only the final average counts as the real measurement, not the individual instance.
##<a> = <\psi|A\psi>##. It's the Born rule expectation. A macroscopic state has a state vector just like a particle. (I have edited my last post to distinguish the macroscopic ##<a>## from the atomic ##<a_i>##.)A. Neumaier said:I don't know what a is, hence not what <a> should mean.
Fair enough. But we're talking QM here. So the distinction between macroscopic and microscopic is quantitative not qualitative.A. Neumaier said:Because all measurements are derived by computations or interpretation from macroscopic measurements. So the latter are the basic objects without which the former cannot even be found. Moreover, macroscopic measurements give meaningful results even without repetition. Hence macroscopic objects have a more realistic nature than microscopic ones.
No. This is your misunderstanding!vanhees71 said:This is a typical misunderstanding of many theoretical physicists. Physics is all about measurements!
There are also no measurements in nature but only in our formal descriptions of nature within scientist's logbooks.vanhees71 said:There are no operators in nature but only in our formal description of nature within QT.
All our success in technology is indeed based on both sides of physics, theoretical and experimental, and thus particularly in the ability to precisely quantify observations of nature, and this quantification is possible only by defining measurement procedures, which includes itself both theory and experiment/engineering. Even to define a simple quantity as the length of my table, I need both theory (basically the assumption about the validity of some geometry of space, in this case Euclidean geometry) and engineering to build a measurement device (in this most simple case simply a meter stick).A. Neumaier said:No. This is your misunderstanding!
Physics is about understanding nature in terms of mathematics. (Galilei: The book of nature is written in the language of mathematics.)
We cannot measure anything in the past or future but still believe that physics draws a reasonably correct picture of dynamics, no matter what is measured.
Technology based on physics works, although nothing or very little is measured. Thus theoretical physics without measurement has lots of healthy uses, whereas measurement without underlying theory does not even get off the ground since a lot of theory is needed to even design and calibrate the devices that create measurements. This shows that theory is the foundation!
Measurements are only used to check the quality of predictions and theories, and to collect data that may lead to better or new theories.
No, a measurement is a very "real" activity and not merely a formal description.A. Neumaier said:There are also no measurements in nature but only in our formal descriptions of nature within scientist's logbooks.
I use ##a## as the value of an observable. ##a_{macro}## is the result of measuring it for a macroscopic system and is an eigenvalue of that system.vanhees71 said:I have no clue what you mean by ##a_{\text{macro}}##.
You use ##A## here as my ##a## and ##\hat{A}## for the operator. But Neumaier uses ##A## for the operator! (Which is why I use ##a## for the variable.)vanhees71 said:We discuss QT, and there expectation values are given by ##\langle A \rangle=\mathrm{Tr} (\hat{\rho} \hat{A})##, where ##\hat{\rho}## is the statistical operator of the system (no matter whether it's "microscopic" or "macroscopic") and ##\hat{A}## is the (usually self-adjoint) operator representing the observable ##A##.
vanhees71 said:No, a measurement is a very "real" activity and not merely a formal description.
vanhees71 said:A measurement is a quantified observation.
An average is an empirical number obtained from a sample; an expectation is a theoretical quantity derived from a theoretical distribution and applied to a single measurement. We expect them to become the same only with an infinitely large sample. Do we agree on that distinction?vanhees71 said:A measurement is a quantified observation. Concerning the confusion with the notation, it is clear that observables are themselves not operators on a Hilbert space but defined as an equivalence class of measurement procedures in the real world. That's why I use ##\hat{A}## for the operator, ##A## for the observable, and the average is either an average over many measurement results on an ensemble of equally prepared systems (that's the case, e.g., for standard scattering experiments with single particles, nuclei, atoms, etc.) or a temporal or spatial average by an measurement apparatus (e.g., if you measure the effecive value of an AC current or voltage or the intensity of light.
I still don't know, what you mean by "measuring a macroscopic system". Macroscopic systems are quantum systems too. I guess what you mean are the usual "bulk observables" of macroscopic system (i.e., a system consisting of very many particles) like single-particle densities/phase-space distributions, the total energy and momentum, the center-of-mass position etc. These behave under usual conditions (e.g., close to thermal equilibrium at finite temperature) classically, because they are averaged over many microscopic degrees of freedom and quantum as well as thermal fluctuations (quantified by standard deviations of the macroscopic observables) are small compared to the typical relevant order of magnitude of changes of these variables just thanks to the "law of large numbers".
Then maybe it is an informal description.vanhees71 said:No, a measurement is a very "real" activity and not merely a formal description.
The total energy is not an average over many microscopic degrees of freedom, neither is the total mass.vanhees71 said:, the total energy and momentum, the center-of-mass position etc. These behave under usual conditions (e.g., close to thermal equilibrium at finite temperature) classically, because they are averaged over many microscopic degrees of freedom
There is no such notion of ''equivalence class of measurement procedures in the real world''; it is your invention!vanhees71 said:A measurement is a quantified observation. Concerning the confusion with the notation, it is clear that observables are themselves not operators on a Hilbert space but defined as an equivalence class of measurement procedures in the real world.
The context in which this quote - in the original emphasized by putting it in italic! - appears shows that he clearly means this and understands its implications.Callen said:Operationally, a system is in an equilibrium state if its properties are consistently described by thermodynamic theory.
It's really very difficult to discuss, if you don't want to understand each other. Born's rule for me applies to both pure and mixed states. For a macroscopic system, of course, we don't measure microscopic degrees of freedom (e.g., the position of all particles within the system), because we are not able to get this information, because it's too complex (if you have 1 mol of a gas, you cannot measure ##3N_{\text{A}}## position components, because it's too much information to store). What you can, however measure is the center of mass, and it's described by the operatorA. Neumaier said:The total energy is not an average over many microscopic degrees of freedom, neither is the total mass.
Even for position, which may be viewed as such an average, the microscopic degrees of freedom are never measured, so Born's rule (which is exclusively about measurement results) cannot apply even in principle!
Yes, and to define, what's the meaning of mass, length, force, etc. you have to give measurement procedures to enable their quantitative observation, and there are many different ways to operationally define the quantities, and as you state yourself it's also changing with time due to the development of new technical possibilities to measure these quantities. That's why I summarized this as "equivalence class of measurement procedures". Of course, I assumed (obviously falsely) what every physics student learns in the first experimental-course lectures, namely that physical observables are defined by appropriate measurement procedures, i.e., operationally in the lab and not as abstract mathematical definitions within some theory.A. Neumaier said:There is no such notion of ''equivalence class of measurement procedures in the real world''; it is your invention!
The collection of measurement procedures for a particular quantity (let us say mass) in the real world strongly depends on time, but still we believe that Newton had the same notions of length, force, or mass in mind that we have today. Moreover, the form and accuracy of measurement procedures varies wildly depending on the size of the object and the details of the procedure, and is always limited. So how can they define a concept in a way that it could subsequently be the subject of theoretical physics?
One needs theory (including a theoretical definition of the quantity). to even determine whether a proposed measuring protocol is in fact measuring the desired quantity. A famous quote of Callen (p.15 in the second edition of his even more famous book on thermodynamics) says:
Thus the theory is always the primary thing, defining everything conceptually, and measurement is the way to check its consistency with the real world.
So you measure once a single operator, and do not take an average of many measurements. But Born's rule only applies to an ensemble of measurements, not to a single one. Your argument about means has weight only if your averages are averages of measurements (to which Born's rule applies), not if your averages are averages of operators, about which Born's rule is silent.vanhees71 said:What you can, however measure is the center of mass
To explain what it means one gives sample procedures that result in approximate measurements - not equivalence classes of procedures. One explains that length is what you measure with a rule, force what one measures with a scale, and time what you measure with a clock. This is enough to create a preliminary correspondence of the theoretical concepts with reality. But it is only a very approximate correspondence since rulers, scales, and clocks have limited accuracy.vanhees71 said:Yes, and to define, what's the meaning of mass, length, force, etc. you have to give measurement procedures to enable their quantitative observation,
This agrees with my claim that measurements are only needed to check a theory's consistency with the real world.vanhees71 said:Even the famous Callen cannot "check its [the theory's] consistency with the real world" without having measurement procedures defined to measure the quantities described by the theory!
So what? I never ever have seen an observable, though I have done lots of measurements. Mass, distance, momentum, charge, etc. are all invisible.vanhees71 said:I never ever have seen an operator in a physics lab, and my experimental colleagues measure observables
What does not apply?vanhees71 said:The formalism you give in your book is not clear at all for application in the physics lab!
It is not my task to "provide the dictionary relating the notion in the book to the notions in the lab", because I take the standard way physicists do this for over 90 years no as sufficient, and the relation you ask for is simply the probabilistic meaning of the quantum state according to Born's rule, no more no less. There's no principle distinction between macroscopic and microscopic observables but only in the systems considered and the degree of coarse-graining to be taken as satisfactory accuracy of determining the "relevant" observables.You just need to augment it by a dictionary relating the notions in the book to the notions in the lab. But this is necessary for the application of any language to anything, hence not the fault of my description. Even a book on experimental physics needs this dictionary to be applicable to the lab, unless you assume that the common language is already known. But then I am allowed to assume this as well!
This is easily done by telling which instruments prepare and measure what; no more. I actually know this dictionary; I have more physics education than you may assume. Once this dictionary is set up one can check to which extent theory and experiment agree.vanhees71 said:It is not my task to "provide the dictionary relating the notion in the book to the notions in the lab" [...] you have to "provide the dictionary relating the notion in the book to the notions in the lab".
