Even Engineers Doodle -- on the ICs they design
  • Thread starter Thread starter Tom.G
    Ic Microscope
Engineers often leave small doodles or symbols on the surfaces of integrated circuits (ICs), which can be discovered when the chips are decapped for analysis. These hidden designs sometimes include team member names or logos, adding a personal touch to the technology. The practice of searching for these doodles has sparked renewed interest among engineers in examining older chips. This playful aspect of engineering highlights the creativity involved in chip design, even at a microscopic level. Such discoveries serve as a reminder of the human element behind technological advancements.
Yeah, whenever we used to de-cap another manufacturer's IC to figure out what went wrong, we would always look around the IC surface to see if they'd left any logos or similar. Every once in a while you might find the project team member names or some interesting symbol... :smile:
Likes davenn and sophiecentaur
If you ever see similar doodles inside some random prototype ASIC, you now know where they came from.
Likes Delta Prime, sophiecentaur and berkeman
Ok, that’s pretty cool. Kudos to the people behind them.
Likes sophiecentaur
for sure
gosh, it's been years since i last did that
i have been reinspired tp decap a few more chips :smile::smile:
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
