I Evolution of a Boltzman distribution
In a classical system at a fixed temperature, energy measurements can be described by a Boltzmann distribution, especially as the number of measurements increases. The discussion raises the question of whether repeated measurements on the same system over time would still yield a Boltzmann distribution, or if the measurements are correlated, affecting the probability of subsequent measurements based on prior results. It highlights the distinction between ensemble averages and time averages in statistical physics, emphasizing that for systems in equilibrium, these averages are generally equivalent, as stated in the ergodic theorem. The nuances of measurement correlations and their implications for statistical behavior are acknowledged but not deeply explored. Understanding these concepts is essential for interpreting results in classical statistical mechanics.
kelly0303
Hello! Assume I have a classical system at a fixed temperature, such that the energy can be described by a Boltzmann distribution at that temperature. If I have a huge number of such systems in that state, and I measure the energy of each one, independently, the probability of measuring a given energy would reach the Boltzmann distribution (in the limit of a large number of measurements). However, if I measure the energy of a system to be ##E_1## and a time ##t## later I measure the same system, and I repeat that many times, would I still get a Boltzmann distribution. My question here is in the classical case, I am not talking about wavefunction collapse (also the way you measure the energy shouldn't be important either). My question mainly is, are the measurements correlated, such that for a given time interval between measurements, the probability of the second measurement depends on the value of the first one?
Just a point of nomenclature: you are worrying about the difference between an ensemble average and a time average for a random process. For a discreet random process (say a coin toss) the two are equivalent I think . There are clearly many nuances here, which is why I offer you the nomenclature for further study...and bow out..
One of the major assumptions of statistical physics is that for a system at equilibrium, ensemble average = time average. This is often referred to as the ergodic theorem.
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Scalar and vector potentials in Coulomb gauge Assume Coulomb gauge so that $$\nabla \cdot \mathbf{A}=0.\tag{1}$$ The scalar potential ##\phi## is described by Poisson's equation $$\nabla^2 \phi = -\frac{\rho}{\varepsilon_0}\tag{2}$$ which has the instantaneous general solution given by $$\phi(\mathbf{r},t)=\frac{1}{4\pi\varepsilon_0}\int \frac{\rho(\mathbf{r}',t)}{|\mathbf{r}-\mathbf{r}'|}d^3r'.\tag{3}$$ In Coulomb gauge the vector potential ##\mathbf{A}## is given by...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
