Why does the series Taylor expand as e^-nx?
  • Thread starter Thread starter unscientific
    Expansion
The discussion revolves around the derivation of the Sommerfeld formula and the Taylor expansion of the function 1/(1+e^x)^2. It highlights the transition from the second to third steps in the derivation, noting differences in the terms produced. The expansion can be achieved by expressing 1/(1+e^x)^2 as e^{-2x}/(1+e^{-x})^2 and applying the binomial series expansion. The conversation also emphasizes the importance of differentiating the geometric series to arrive at the correct terms for the series expansion. Ultimately, the method leads to the general expression for the series expansion as e^{-nx}.
unscientific
In this section, they derive the Sommerfeld formula.
In the first step it seems like they have expanded ##\frac{1}{(1+e^x))^2}##. I'm not sure why does the series taylor expand as ##e^{-nx}##?
Also how did they get from the 2nd to the 3rd step?
Simply by comparing terms we see they are different:
For 2nd step we get terms of ##x^se^x(-1 + 2e^{-x} - 3e^{-2x} + ...)##.
For 3rd step we get terms of ##e^{-x} - 2e^{-2x} + 3e^{-3x} - ...##
Yeah in the second step it needs to be multiplied by -1 and the e^x should be e^(-x) instead.
To get the expansion, you could write \frac{1}{(1+e^x)^2} as \frac{e^{-2x}}{(1+e^{-x})^2}. Then you could do the binomial series expansion on it, or you could write it out using the geometric series formula, which gives \frac{e^{-2x}}{(1+e^{-x})^2}=e^{-2x}(1-e^{-x}+e^{-2x}-e^{-3x}+...)^2. Collecting the terms that come from squaring it, you get the appropriate formula.
chingel said:
... \frac{e^{-2x}}{(1+e^{-x})^2}=e^{-2x}(1-e^{-x}+e^{-2x}-e^{-3x}+...)^2. Collecting the terms that come from squaring it, you get the appropriate formula.
Collecting the terms give the right terms, but how did they obtain a general expression ##\sum_{n=0}^{\infty} e^{-x} [(n+1)(-1)^{n+1} e^{-nx}]##?
To expand ##\frac{1}{(1 + e^{-x})^2}##, do it in terms of ##y = e^{-x}##.
\frac{1}{1 + y} = \sum{(-1)^n y^n}
Differentiate both sides wrt ##y##:
- \frac{1}{(1 + y)^2} = \sum{(-1)^n n y^{n-1}} = \sum{(-1)^{n+1} (n+1) y^n}
Likes 1 person
Actually I think it's ##e^x## instead:
Starting, LHS is simply geometric series with factor ##e^{-x}##:
\frac{1}{1+e^x} = \sum (-1)^n e^{-nx}
Differentiating both sides with respect to x,
-\frac{e^x}{(1+e^x)^2} = -\sum (-1)^{n+1} n e^{-nx}
\frac{e^x}{(1+e^x)^2} = \sum (-1)^{n+1} n e^{-nx}
This leads to the answer immediately.
  • · Replies 16 ·
  • · Replies 17 ·
