swap1996
- 10
I have a very simple question. If a hole is made at the center of a metal plate and it is heated to increase its temperature, will the hole increase in size or decrease?
swap1996 said:I have a very simple question. If a hole is made at the center of a metal plate and it is heated to increase its temperature, will the hole increase in size or decrease?
berkeman said:It kind of makes sense that if you draw a circle on the plate and heat it, the circle will grow with the plate.
AlephZero said:There are materials (e.g. many crystals, and some composite matierals) where the coefficient of thermal expansion is different in different directions. In those materials, in general the hole would not expand uniformly, and would change shape.
But apart from that:
If the solid plate is at a constant temperature and the edges are free to expand, the stress in the plate will be zero everywhere, independent of the temperature.
So, imagine that you draw the circle, then change the temperature of the plate, then cut out the hole around the expanded or contracted shape of the line. Since the stress in the plate was zero everywhere before cutting, it will stay zero after cutting, and cutting the hole wll not change the shape of the plate.
Or more mathematically:
If there is no elastic stress in the plate, the strain field is ##\epsilon_{xx} = \epsilon_{yy} = \epsilon_{zz} = \alpha \Delta T## and the shear strains are all zero, where ##\alpha## is the corefficient of expansion and ##\Delta T## the temperature change.
Because the strain field is symmetrical in x y and z, this means that ANY two points that were originally a distance ##d## apart become a distance ##d(1 + \alpha \Delta T)## apart, indepedent of the shape of the object, and whether or not it contains holes.
