Expectation of a sum of random variables
In summary, the expectation of a sum of random variables states that the expected value of the sum is equal to the sum of their expected values. Mathematically, if \(X_1, X_2, \ldots, X_n\) are random variables, then \(E(X_1 + X_2 + \ldots + X_n) = E(X_1) + E(X_2) + \ldots + E(X_n)\). This property holds true regardless of whether the random variables are independent or not, making it a fundamental concept in probability theory and statistics.
docnet
486
Given ##E[A]=0## and ##E[B]=b##, can ##E[(A+B)^2]## be simplified?
##E[A]## is the expectation of ##A##.
$$\begin{align*}
E[(A+B)^2]&=E[A^2+2AB+B^2]\\
&=E[A^2]+2E[AB]+E[B^2]\\
&=2E[AB]+E[B^2].
\end{align*}$$
Can the terms ##2E[AB]## and ##E[B^2]## be simplified any more? Thanks, friends.
How did you estimate E[A^2]?
E[ AB ]=E[ A ]E[ B ]
anuttarasammyak said:
E[AB]=E[A]E How did you estimate ##E[A^2]##?
Oh I have made a mistake.. we do not know that ##E[A^2]=0##.
If ##A## takes values ##-1## and ##1## with equal probability then ##A^2=1## with probability ##1##. So ##E[A^2]=1.##.
Thank you!
Likes Gavran and anuttarasammyak
This is only valid if [itex]A[/itex] and [itex]B[/itex] are independent (it doesn't hold, for example, when [itex]A = B[/itex]), and we are not told that they are.
Using [tex]\newcommand{\Var}{\operatorname{Var}}\Var(X) = \mathbb{E}[X^2] - (\mathbb{E}[X])^2[/tex], we have [tex]
\mathbb{E}[(A + B)^2] = \Var(A + B) + (\mathbb{E}[A + B])^2 = \Var(A + B) + b^2.[/tex]
Likes docnet, anuttarasammyak and WWGD
That is extremely useful ! Thanks.
I can think further of your example when ##A=B \sim~N(0,1)##, so that ##A^2 \~ sim mathbb Chi^2(1)##, with expectation/expected value ##1##, while ##E[A]=0##, so that ##E[A^2]=1 \neq E[A]E[A]=0.0=0##
Likes docnet
I can think further of your example when ##A=B \sim\mathbb N(0,1)##, so that ##A^2 \sim \mathbb{ \chi^2(1)}##, with expectation/expected value ##1##, while ##E[A]=0##, so that ##E[A^2]=1 \neq E[A]E[A]=0.0=0##
Likes docnet
WWGD said:
I can think further of your example when ##A=B ## ~##\mathbb N(0,1)##, so that ##A^2 ## ~##\ mathbb \chi^2(1)##, with expectation/expected value ##1##, while ##E[A]=0##, so that ##E[A^2]=1 \neq E[A]E[A]=0.0=##
Try ##\sim##
Likes WWGD and docnet
Orodruin said:
Try ##\sim##
Thanks, fixed it. Phew! Need an upgrade and refresher on my Tex.
Likes docnet
What is it meant by simplified? $$ E [ ( A + B ) ^ 2 ] $$ is simpler than $$ E [ A ^ 2 ] + 2 E [ A B ] + E [ B ^ 2 ] $$ and demands less calculation. Only in the case where A and B are independent $$ E [ ( A + B ) ^ 2 ] $$ can become a simpler expression which is $$ E [ A ^ 2 ] + E [ B ^ 2 ] $$ and which demands less calculation.
Likes docnet
[itex]A[/itex] and [itex]B[/itex] being independent does not imply that [itex]E[AB] = 0[/itex].
Likes docnet
It does if you pair it with ##E[A]=0## as given in the OP.
Likes docnet
FAQ: Expectation of a sum of random variables
What is the expectation of the sum of two random variables?
The expectation of the sum of two random variables is equal to the sum of their expectations. Mathematically, if \(X\) and \(Y\) are random variables, then \(E[X + Y] = E[X] + E[Y]\).
Does the expectation of the sum of random variables require them to be independent?
No, the expectation of the sum of random variables does not require them to be independent. The linearity of expectation holds regardless of whether the random variables are independent or not.
How do you generalize the expectation of the sum for more than two random variables?
The expectation of the sum of more than two random variables is the sum of their individual expectations. For random variables \(X_1, X_2, \ldots, X_n\), the expectation is \(E[X_1 + X_2 + \cdots + X_n] = E[X_1] + E[X_2] + \cdots + E[X_n]\).
What is the expectation of the sum of a constant and a random variable?
If \(c\) is a constant and \(X\) is a random variable, the expectation of their sum is \(E[c + X] = c + E[X]\). This follows from the linearity of expectation.
Can the expectation of the sum be used to find the variance of the sum of random variables?
While the expectation of the sum is straightforward, finding the variance of the sum of random variables requires additional information about their covariance. For independent random variables \(X\) and \(Y\), the variance of their sum is \(Var(X + Y) = Var(X) + Var(Y)\). For dependent variables, the covariance term must be included: \(Var(X + Y) = Var(X) + Var(Y) + 2Cov(X, Y)\).
