Expected Value of a Function (Standard Normal)
In summary: E[Zf(e^aZ)] = e^a ∫-∞∞ f(v-a)e^(-(v-a)^2/2)/a dvFinally, we can use the fact that f is a measurable function and substitute in the derivative of f evaluated at e^(a(Z+a)). This gives us:E[Zf(e^aZ)] = e^a ∫-∞∞ f(v-a)e^(-(v-a)^2/2)/a dv = e^a f'(e^(a(Z+a))) ∫-∞∞ e^(-(v-a)^2/2)/a dv = aE[e^
rp2000ap
Let Z be a standard normal random variable, f is a measurable function and a is a constant.
Show E[Zf(e^aZ)] = aE[e^aZ]E[f'(e^(a(Z+a))]
I set up an integral from negative to positive infinity of
z*f(e^aZ)*e^((-z^2)/2)*1/sqrt(2pie)*dz
My 2 questions are can I combine the z from the pdf of the normal distrbution function into f(e^aZ) and does the z in the beginning of my equation require integration by parts to evaluation the integral.
Thanks!
Hello!
Let's start by defining some terms and understanding what the problem is asking for. A standard normal random variable, Z, is a random variable with a mean of 0 and a standard deviation of 1. This means that the probability density function (pdf) of Z is given by f(z)=1/sqrt(2π)e^(-z^2/2). A measurable function, f, is a function that maps measurable sets to measurable sets. And a is a constant.
Now, the problem is asking us to show that the expected value of the random variable Z multiplied by the function f(e^aZ) is equal to the product of the expected value of e^aZ and the derivative of the function f evaluated at e^(a(Z+a)). In other words, we need to show that E[Zf(e^aZ)] = aE[e^aZ]E[f'(e^(a(Z+a)))]
To do this, we can start by writing out the expected value of Zf(e^aZ) in terms of the pdf of Z. This is given by:
E[Zf(e^aZ)] = ∫-∞∞ zf(e^aZ)f(z)dz
Now, we can use a change of variable to simplify this integral. Let u=e^aZ, then du=a*e^aZ*dZ. This means that dZ=du/(a*e^aZ) and we can rewrite our integral as:
E[Zf(e^aZ)] = ∫-∞∞ f(u)du/(a*e^aZ)
Next, we can use the fact that Z is a standard normal random variable, and substitute in the pdf of Z. This gives us:
E[Zf(e^aZ)] = ∫-∞∞ f(u)du/(a*e^aZ) = ∫-∞∞ f(u)e^(-u^2/2)/a*e^aZ du
Now, we can simplify this even further by using the fact that e^aZ is a constant with respect to the integral and can be pulled out. This gives us:
E[Zf(e^aZ)] = e^a ∫-∞∞ f(u)e^(-u^2/2)/a du
Next, we can use another change of variable, let v=u+a,
FAQ: Expected Value of a Function (Standard Normal)
What is the expected value of a standard normal function?
The expected value of a standard normal function is 0. This means that if you were to take an infinite number of measurements from a standard normal distribution and calculate the average, it would be equal to 0.
How is the expected value of a function calculated?
The expected value of a function is calculated by multiplying each possible outcome by its corresponding probability and summing these products. For a standard normal distribution, the formula for the expected value is E(x) = ∫x*f(x)dx, where f(x) is the probability density function.
Why is the expected value of a standard normal function important?
The expected value of a standard normal function is important because it helps us understand the central tendency of a distribution. It is also used in many statistical calculations, such as calculating the variance and standard deviation.
What does the expected value of a standard normal function tell us about the distribution?
The expected value of a standard normal function tells us that the distribution is symmetric around the mean of 0. This means that the majority of the data falls within a certain range around the mean, and there are equal amounts of data on either side of the mean.
Can the expected value of a standard normal function be negative?
Yes, the expected value of a standard normal function can be negative. This can occur if the distribution has a long tail on the negative side, pulling the mean towards the left. However, in a standard normal distribution, the expected value is always 0.
