Expected values for random variables
cue928
I am stuck on the following problem: Five items are to be sampled from a large lot of samples. The inspector doesn't know that three of the five sampled items are defective. They will be tested in randomly selected order until a defective item is found, at which point the entire lot is rejected. Y is the number of firing pins the inspector must test. Find, graph the probability distribution of Y.
I understand that p(1) = 3/5. But it is saying that p(2) =3/10 and p(3)=1/10, I do not see how they are calculating that.
So p(2) is the probability that the second sample tested is defective. That means that you are looking at the case where the first one is non-defective (otherwise testing would stop there!) and the second one is broken.
What are the probabilities for each of those? Then how do you calculate p(2)?
That's what I can't figure out. Is p(2) asking what the chance of the second draw being defective?
It says "Y is the number of firing pins the inspector must test." and that they will stop testing the moment a defective item is found.
p(2) is "sloppy" shorthand for P(Y = 2), that is: when you do the experiment, what is the probabillity of finding the value 2 for Y.
After finding that the first item is non-defective, how many items are left to test? How many of those are defective?
RGV
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
