Expelling warm air from voids - what is left afterwards?
In summary: Overall, heating the cylinder slowly may help reduce the presence of air pockets in the melted plastic, but it may also introduce other issues like stratification and oxidation. Applying a vacuum before heating may be a more effective solution to remove air from the mixture. However, if the material in question is graphite, its oxidation may not be a concern if the temperature is kept below 400C.
EddieP
A cylinder contains a powder made up two substances - spherical grains of metal and spherical grains of plastic. In between the grains are voids, so that the cylinder is made up of 75% powder grains and 25% air. The cylinder is oriented vertically. It is sealed at the bottom and open at the top.
The cylinder is heated, and the plastic grains start to melt. The air in the voids gets less dense as the temperature increases, and rises. Some of the hot air leaves the cylinder, but some of the air gets trapped in the melting plastic, and forms small pockets of air encased in the now melted plastic.
Would heating the cylinder slowly allow for more of the air to leave the voids before the plastic is melted? Or, would this rising air just be replaced by falling cooler air that fills the voids?
Science news on Phys.org
The heated air that can escape should be replaced by melting plastic, I believe.
I see additional problems due to the possible difference of densities between metal and plastic, inducing stratification, as well as air oxidizing the metal at high temperatures.
Those negative effects could be reduced by applying vacuum to the mix previously to the beginning of the heating process.
Is that feasible?
Likes EddieP
Is that feasible?
Thanks Lnewqban,
I appreciate your answer. The vacuum would be ideal, but it is an extra step I am trying to avoid if I can.
With regards to the oxidation, I should have said the material in question is actually a graphite powder. Sorry, I overlooked mentioning that. It seems that graphite starts oxidizing at 400C - if I keep the temperature under this, is it safe to assume that oxidation will not be an issue, or does oxidation occur in minute amounts at lower temperatures?
EddieP said:
Thanks Lnewqban,
You are welcome.
In that case, the melted mix may allow some of the reduced density bubbles to slowly reach the surface, but not without fighting the viscosity and possible convection movement of the hotter mix.
I don't know enough about it to give you any opinion on oxidation of graphite, sorry.
It is also possible that the air bubbles will dissolve in the molten plastic if the plastic is not initially saturated with air at the higher temperature.
Likes Lnewqban
Related to Expelling warm air from voids - what is left afterwards?
1. What is the purpose of expelling warm air from voids?
The purpose of expelling warm air from voids is to regulate the temperature and air flow within a space. This can help maintain a comfortable environment for occupants and prevent potential damage to the structure or contents of the space.
2. How does expelling warm air from voids work?
Expelling warm air from voids typically involves using a ventilation system to remove the warm air and replace it with cooler air from the outside. This can be achieved through natural ventilation, mechanical ventilation, or a combination of both.
3. What are the potential benefits of expelling warm air from voids?
The benefits of expelling warm air from voids include improved air quality, reduced humidity levels, and energy savings. It can also help prevent the growth of mold and mildew, and protect sensitive equipment or materials from heat damage.
4. Are there any potential risks or drawbacks to expelling warm air from voids?
One potential risk of expelling warm air from voids is the introduction of outdoor pollutants or allergens into the space. Additionally, if the ventilation system is not properly designed or maintained, it may not effectively remove the warm air and could potentially cause damage to the structure or equipment.
5. How can I determine if expelling warm air from voids is necessary for my space?
If you are experiencing issues with temperature regulation, humidity levels, or air quality in your space, it may be beneficial to consider expelling warm air from voids. Consulting with a professional HVAC technician can help determine the best solution for your specific needs.
  • Materials and Chemical Engineering
