Experiment with high voltage that can show arcs / stun human
The discussion revolves around experimenting with high voltage, specifically modifying an electric mosquito swatter to enhance its performance. The user notes the swatter's half-wave rectifier and questions the voltage readings, observing 400 volts DC and 1000 volts AC. Responses emphasize the dangers of working with high voltages and the importance of electrical safety, discouraging any attempts to create devices intended to stun humans. Suggestions are made to explore safer alternatives like Tesla coils for generating arcs without the risks associated with stun devices. The thread concludes with a warning against weaponizing electrical experiments, leading to its closure.
leonar
I'm very interested in Experiment with high voltage that can show arcs.
I also like to modify my swatter ( electric racket to kill mosquito/ flies), it is made in china.
About the swatter:
-It has only one diode at the secondary winding of the trafo, ithink this is for rectifying the ac that produce by the trafo and make dc so the power can be stored in the huge capasitor. But ithink the rectifier is not good enough, it's half wave rectifier. How if we change it to full wave rectifier with diode bridge?
-I've measured the voltage of this swater. I get about 400 volt DC when i use DC measuring with my multitester, but when i measure in ac i get about 1000 volt ac. Can anybody explain this? Why there is ac and dc volt?
-There's huge capacitor in the secondary winding at the trafo. This ceramic caps add more sparks when we short the iron at the racket. Do you know about the capacity and the working voltage of this huge caps? I think it's a good idea to add more caps like this and parallel them with this caps to add more sparks
Sorry I can't help you with more, but if you are rectifying the transformer signal you will get a DC value always (I assume you are confused why there is a DC voltage). DC in the frequency spectrum corresponds to the average value of the AC voltage, so naturally a rectified signal will have some nonzero average value.
Anyone can help me please?
leonar, we are not going to help you experiment with building your own stun gun for humans. Besides the danger to yourself, working with high voltages and obviously not understanding the basics of electricity and electrical safety, there is the issue of what you intend to do with it.
A better approach if you just want big pretty arcs is to look at Tesla coils:
http://en.wikipedia.org/wiki/Tesla_coil
You can get help with many things here on the PF, but helping you to make weapons, even if it's just for fooling around, that is something that we do not do.
Thread locked.
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Thread 'How Does Jaguar's 1980s V12 Dual Coil Ignition System Enhance Spark Strength?'
I have come across a dual coil ignition system as used by Jaguar on their V12 in the 1980's. It uses two ignition coils with their primary windings wired in parallel. The primary coil has its secondary winding wired to the distributor and then to the spark plugs as is standard practice. However, the auxiliary coil has it secondary winding output sealed off. The purpose of the system was to provide a stronger spark to the plugs, always a difficult task with the very short dwell time of a...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
